I missed the original thread. I love reading posts like these. People definitely get attached to their older machines. That machine looks super, good attention to detail and anti-skid tape to keep your mom from slipping. Nice work, guys!
Probably too early to tell, but, how is the engine holding up so far?
The outfit that made the decals ought to have the program available to print out another set.
Thanks! It was a fun project. The engine has been holding up well, but there are a few things that we have found. The engine is not quite as peppy as I was hoping. I should have went with a few more horses, but it does work. The next issue we found was cold starting. When the engine cranks hard with cold hydros, the ignition system does not get enough voltage to fire. I need to sneak in a cap and a diode to make a start circuit to help with that. The engine does run pretty warm in the semi-confined area, so I am going to mount a fan with a thermostat on top of the engine area to cool the engine a bit better.
The v-twin seems to not run quite as smooth as the old opposed cylinder Onan. The gearbox chatters quite a bit more, but other than knocking the coupler loose a few times, it seems to do pretty good at high idle.
