Injector pump timing
Mike 1150b
Hermann
Can anyone tell me what degree timing should be on when checking the marks at the pump. I have a case 1150b with the 451 bd engine. The engine info decal has been painted over. Manual gives instructions to refer to that decal. Thanks Mike.
thepumpguysc
Sunny South Carolina
Master Inj.Pump rebuilder
If I remember correctly its like 32*..34*??
I take it u found the pointer & the timing line for the inj. pump??
The inj. pump timing line is VERY VERY small & is located on the front bearing plate..
alrman
QLD Australia
It would be 30 deg btdc ;)
Mike 1150b
Hermann
Yes, i had installed new injectors and just wanted to double check timing on fuel. Fires right up and runs great. Thanks!
