information on CATERPILLAR IT series loaders, what a difference between the other strengths and weak
trombeur
italia
hi excuse me for the question how do the caterpillar IT series wheel loaders differ and in comparison with the G series? I remember a series of wheel loaders that had a tubular box-like arm and a telescopic series of the JCB type. could you please report me series and model, thanks.
John C.
The boom and tilt linkages on an IT machine also have a quick coupler installed from the factory. The difference in the linkages is that the IT machine will lift the bucket in such a way as to stay at the same angle as it was when it was lower. The IT machines usually have pallet forks as one of the attachments and are used extensively on port docks and marshaling yards for handling palletized materials. The rest of the machines are the same.
trombeur
italia
the caterpillar IT would be the most versatile multi-tools of the "normal" wheel loaders, which maybe used to move the aggregates with the bucket, would they be handyman forklifts, I presume?telescopic handler??
John C.
You can get a boom for an IT machine but it is solid. It does not extend and can best be described as a modified I beam with a quick coupler installed on one end and a hook on the other.
trombeur
italia
you could insert a photo kindly I think I have seen some machines with telescopic arm I think 924 G series IT but I could be wrong, an acquaintance of mine would like one to be used in a small shipyard both as a crane to lift and move and for hauling and launching boats from the beach and as a large forklift to move boats in its yard undergoing maintenance. thank you. I had suggested the classic telescopic it caterpillar, but he tells me better the wheel blade, it is higher then it has a greater radius and greater maneuverability, when I go to pick up the hulls on the sand of the beach. to the arm there should be a sturdy one
spreader beam with Lifting Sling Strap Strop attached. I said find an old excavator is more versatile.
Construction_machinery_Wheel_loader_CATERPILLAR_930_G_High_Lift-xxl-7881_5521181149.jpg
images
images
