Inch drive sockets, deep or shallow
Discussion in 'Shop Talk' started by STOIE, Dec 11, 2012.
  1. STOIE
    STOIE Member
    Aug 21, 2012
    13
    Canberra, Australia
    Hey all,
    I am thinking of investing in my first set of inch drive sockets...
    However, not sure weather I should buy deep sockets or regular sockets.
    The normal sockets are $350 for a set and the deep sockets are $520.
    I know deep sockets should do everything regular ones will, plus more, but, will I actually need them?
    Is it worth the extra expense?
    I really want to avoid buying these twice...
    Will be working on alot of farm machinery including possibly a D6H or D8H in the future.
    Which also leads onto another quick question, does anyone have a list of required socket sizes for a D8H? (is 1-1/2 inch drive required? - again if so, sizes?)
    Aaron.
  2. siduramaxde
    siduramaxde Member
    Nov 27, 2011
    24
    Illinois
    I would kick myself if I didn't spend the extra money when I got to that one nut that required deep well
  3. willie59
    willie59 Administrator
    Dec 21, 2008
    12,834
    Service Manager
    Knoxville TN
    True enough siduramaxde, always a possibility it can happen. However, in most cases, on machinery, most of the time you're simply working with a bolt head, no worries there, and the times you're working with a nut the bolt threads rarely protrude very far through the nut. Yes, there are exceptions, just saying it's not the norm. And there are times when I've stuck an impact in an enclosed area that a deep socket or an impact with an extended anvil would not fit in the area. Just my preference, but I prefer my set up to be as short as possible. If I run across the rare place that deep well is required, I'll figure out how to deal with it. ;)
  4. Lee-online
    Lee-online Senior Member
    Jan 16, 2010
    1,023
    In a van, down by the river
    Our inch drive sockets go up to about 5" and most are shallow. We use Rad guns with them and the deep cause more problems because they are too long.
  5. FSERVICE
    FSERVICE Senior Member
    Apr 2, 2009
    635
    indiana
    my 1" drive sockets are shallow well. that being said i have several common size deep well on the truck as well. that seems cheap for 1" drive, dont go the cheap route on these sockets especally if you plan to work them everyday;)
  6. theironoracle
    theironoracle Senior Member
    May 5, 2012
    940
    OWNER/OPERATOR MOBILE HEAVY EQUIPMENT REPAIR
    PACWEST
    stoie, i assume your talking about impact sockets? i carry both up to 3" with extensions 3,6,9,12", i actually think i would buy the deep first. right off i can think of 3 very specific jobs where you remove the nut and don't access bolt head, 1) plow bolts, 2) ripper or grapple bolts where they attach to the rear of the tractor that must be removed for high track trans removal, 3) blade trunion bolts to remove push arms to work on undercarriage. i have had great luck with my grey pnuematic socket sets not supper high end but good economy tools..................theironoracle
  7. mitch504
    mitch504 Senior Member
    Feb 27, 2010
    5,445
    Andrews SC
    I have a full set of the shallow up to around 3.5" , and have bought deep along and along over the over the years as needed. I have basically a full set of both now.
    I do about 60% trucks and 40% equipment, and there are a few places on trucks where you will need deep ones. Things like lug nuts, spring u-bolts, and a few others.
    If you are going to do much w/ heavy trucks, you basically need a full set of 3/4 drive in deep and shallow also.
  8. STOIE
    STOIE Member
    Aug 21, 2012
    13
    Canberra, Australia
    Thanks for the responses guys.
    I plan on buying a full set of both deep and shallow in the end, but, just after an idea on what the get first.
    @Mitch - I don't have any 3/4 stuff, but, I have 1/2 up to like 35mm. (again, will probably invest in 3/4 down the track but, think I can get past more things with 1" for now.
    Does anyone have any advise on good set of inch drive sockets? (good brands etc.)
    Thanks again,
    Aaron.
  9. RobVG
    RobVG Senior Member
    Jun 20, 2009
    1,028
    17 excavators and a stewpot of other stuff
    Seattle WA
    I use a 3/4 to 1" impact adapter if I need to use a 1" dr socket, but mostly use 3/4 dr sockets. A 3/4 breaker bar and/or impact wrench usually suffices. I work on trucks and excavators up to 160's. The largest bolts I have to deal with on a regular basis are 1" torque rod bolts. And occasionally I have to replace a pintle eye and bushings on one of our trailers and the flame wrench seems to work best.
  10. RobVG
    RobVG Senior Member
    Jun 20, 2009
    1,028
    Seattle WA
    My favorite deep socket is one I made. It's a 3/4" socket 1/2"-drive and 6" deep. Any guesses what it's for?:D
  11. STOIE
    STOIE Member
    Aug 21, 2012
    13
    Canberra, Australia
    Yeah understand where your coming from, I just feel that it's easier to transfer more torque through a inch drive.
    As for your socket... no idea, but, I am sure you will fill me in?
  12. RobVG
    RobVG Senior Member
    Jun 20, 2009
    1,028
    Seattle WA
    I don't know STOIE, i've broken plenty of bolts with my three quarter. ;)
    (I use the socket for caging brake spring cans)
  13. STOIE
    STOIE Member
    Aug 21, 2012
    13
    Canberra, Australia
    Haha I bet.
    And neat idea, made it yourself aeh!
  14. equip guy
    equip guy Well-Known Member
    Nov 17, 2010
    95
    Ag and Construction Equip mechanic
    Massachusetts
    As for good quality (not cheap $$$) try looking at Proto or Wright.
  15. STOIE
    STOIE Member
    Aug 21, 2012
    13
    Canberra, Australia
    Awesome will check them out.
    Cheers,
  16. powerjoke
    powerjoke Senior Member
    Aug 2, 2009
    1,125
    owner/operator/estimator/mechanic/grunt/ditchdigge
    Missouri
    Go to harbor freight and spend $250 on both!
  17. biggrader
    biggrader Well-Known Member
    Jan 16, 2010
    219
    Owner/Operator
    Red River Valley of the North
    Not sure if this is the correct answer, but we have a 3/4" socket 1/2" drive , cut in two with a 12" long pipe welded back in. We use it to tighten culvert band bolts.
  18. biggrader
    Jan 16, 2010
    219
    Owner/Operator
    RobVG Did I win , Did I win, Did I win, huh, huh, huh !!!
  19. Impact
    Impact Senior Member
    Nov 29, 2009
    510
    Owner
    Kentucky
    Shallow fractional
    Deep Fractional
    Shallow Metric
    Deep Metric
    :eek:
  20. Greg
    Greg Senior Member
    Jan 28, 2008
    1,175
    Excavating Contractor
    Wi
    A new Wright 1.0" set will set you back about $1,500.00. It will be shallow and 12 point. These are not impact sockets. It will come with a ratchet, and a tee bar. I found mine just a teeny tiny bit used, as in one socket used on ebay for $520.00. Yes, I can sleep at night too. This thing is heavy enough to use with shallow sockets let alone putting deep wall on it.
    Don't buy cheap tools, they are no bargin
