Robert M
I've got an old IH 500 that I use for dragging the occasional log out of the woods and genral duty work around my place and brothers farm
Couple weeks ago I was driving it across a field, turned it to the right a little bit and it just stopped, no warning no slippage just stopped. I pulled the top of the 3 speed transmission, with it running the reverser in gear and the trans mission in neutral it doesn't even try to spin the tranny over. not even a twitch.
It is circulating oil big time though. I've been told they have a habit of wiping the splines out on the stub shaft that drives the pump. If that was the case I wouldn't think I would have hydraulic flow at all. Even if that was the problem you would think it either wouldn't be circulating the oil and that it would at least twitch the input shaft a bit.
I pulled the valve on the side and can't find anything wrong with it. I'm guessing anything else is going to require pulling the engine to get the reverser and tranny out.
What should I be looking for? The oil does have a very slight burnt smell to it. What oil should be in it? I think it had 10 weight hydraulic in it. I don't remember. One of my nephews and I rescued it out of the weeds 7 years ago and I doubt we have put 100 hours on it in that time.
