tractorpoor
Rust in the tank
on the 2400a There is a drain plug on the gas tank. Bottom Left hand side if you are looking at it from the rear. You might be able to flush the rust out through it. Otherwise, the tank isn't impossible to remove. A bunch of nuts and bolts that connect it to the fenders (and fuel lines on bottom). I did mine because it was rusted and slightly leaking. I was going to replace it, but ended up using a product called POR-15. Put it back on and it has been fine so far.
