Ignition Switch
Discussion in 'Computer Applications and 3D Modeling' started by Nige, Feb 5, 2013.
  1. Nige
    Nige Senior Member
    10,897
    Having some issues with an ignition switch for a small generator powered by a gas engine. The original switch has 5 connections on it, 4 of which I'm pretty sure what they are based on past experience, but what is the 5th one..? BTW, if I have any of the first 4 wrong please holler ......
    #30 - Battery +
    #50 - connection to starter motor
    #15 - Ignition circuit
    #75 - Accessory Circuit
    #83 - ??
  2. willie59
    willie59 Super Moderator
    Dec 21, 2008
    12,216
    Service Manager
    Knoxville TN
    What type of gas engine, small one or two cylinder air cooled? Or something like a 4 cyl with ignition coil and distributor?
  3. Cmark
    Cmark Senior Member
    Jan 2, 2009
    1,973
    83 is "multiple-position switch input"
    Not sure what that means in the context of an ignition switch. Maybe the switch contains an internal solenoid to stop it being turned to start if the engine is running, or something?
  4. OzDozer
    OzDozer Senior Member
    Jan 19, 2007
    449
    Semi-Retired ..
    Perth, Western Australia.
    Nige, your DIN numbers are correct. #83 is only ever listed as an "input". It would help if the genset make/model was found or provided, you may be able to find a wiring diagram online.
    http://en.wikipedia.org/wiki/DIN_72552
  5. Diagonal Brace
    Diagonal Brace Well-Known Member
    Jan 9, 2006
    176
    Winnipeg Manitoba Canada
    Handy reference there
  6. Nige
    Nige Senior Member
    10,897
    Thanks to all who replied. The link to the DIN Standard was exteremely useful.
