IDIGBEST reviews?
WA
When I talked with Sitech about a 2d system for our Kubota it was close to 15k. Up to 20 depending on options. 37k sounds like a base level 3d system.
HighFlyerAK
Alaska
I should hear from her today, as she promised to go through item per item and the need for it. Being ready to go 3D was part of it, but I was also told that that price won‘t change too much initially.
And I just got an email from the german sales rep in regards to the 3D iDig-System. I will be curious how it will price out and to what level it can support side-swing and tilt-rotator!
Still no response from LEICA, so far..
KSSS
Idaho
excavation
I PMed you the contact info for the regional Leica guy.
steve waldner
huron sd
My 2 cents having had automatics on my e42, I actually chose to go for an indicate only system with Trimble.
For what I do, which is dig trenches for pipe, basements, and slabs, although automatics are certainly nice, they weren't worth the added cost to me. The big thing I needed to speed up operations was to eliminate the guy holding the grade rod, not help me run the shovel. Automatics buy skill, and if you have super tight tolerances, they do have value. But for basements and slabs, the concrete guys that follow me are over the moon if I'm +/- 1/2"-3/4". With many of these systems they can be configured to emit a tone, just like a laser receiver. Eventually you learn to just grade by ear.
Then the Idigbest is the system for u , very accurate fast , and for a little $ u add hyd assist , and it helps dig on grade a lot faster .
fourwheel1
Millersburg ohio
excavating & farming
Do not bother with auto on I dig best,, it is far from auto... Auto on a dozer means blade stays on grade even in mid air,. This system does not work like that, operator still has to control boom weight which controls the grade. It will go below grade if not careful. It is very accurate and fast. Wires running to sensors are very thin and will break, do yourself a favor and build or source a better wire.
IDIGBEST
noblesville, IN.
excavator
Can Phil from I dig Best give an up to date review. Id like to hear how it compares to the Trimble Earthworks 2d for an excavator which costs around $15k incl installation and 7" display as they quoted me Nov. 2020 No automatics though but can be added for around another $10k
IDIGBEST
noblesville, IN.
excavator
The Trimble system is well over priced in for Gps Guy's small businesses overrated. Trimble likes to buy systems for people or give them deals. I can't refuse so they write good reviews. Ask some of the guys writing on here if that's not true. I'm going to have some customers that don't get it and that's OK but I can guarantee you one thing about the system. If you have a problem you can call me if I don't answer call me again, I container system better than anybody on earth. Some of the guys riding on here has 6 inches of slop in their bucket pan and they're still getting grade wondering why it gets off a little bit. I guarantee you that any of you have a problem fly me out to your machine And we'll do a video together with you bragging about it. But somehow there aren't real machine operators either. Through Covid in times people can save money doing their own installs. I suggest flying me out to your install. You have to want the system to work for you to get the best out of it . This is like a good race car they can win all the races but you gotta keep up with it and I'll help is free forever.
IDIGBEST
noblesville, IN.
excavator
Trimble and Leica both offer the position sensor that is attached to the Steelwrist or Rototilt attachment. I don't think you would ever see that come on the attachment itself since there are several possible options on what brand the customer chose for a guidance solution and some may not want that option at all.
Idigbest system works well till rotators. You'll learn that you don't need a rotation sensor. You don't dig sideways if you do and you need to know an exact grade just rotate your bucket back square and touch left side center or right side to see your exact grade. I think Vasco dig forward and reverse, and any tilt angle on the tilt rotator. In a can do better than the competition if anybody would like to compare, let me know. Trimble Leica, Topcon I'll have more latency or delay. Therefore, their accuracy is that like Idigbest, Idigbest is like a CNC every millimeter you know exact grade instantly. It allows the human to work and change on the floor. Without pushing the buttons you got it won't work guys no matter what system it is turn your race car that's how champions work.
IDIGBEST
noblesville, IN.
excavator
Sounds like "I dig just fine" without it and the headaches. To be fair though,you could have gotten one made on a Friday, but the last thing you want to hear as an end user from the manufacturer is "we are stumped", gee thanks, you're stumped and I'm a lot lighter in the pocket.
You need to read a little farther in his remarks you'll see that after I went and helped him is able to dig correctly now. He's talking about it drifting up and you have to check your grade. He's not telling you that his Kobelco bucket has approximately 6 inches of sway forward and back. The bucket pins have never been greased, but the Dig System still can get a perfect grade if he pays attention to it. There's no other Dig System that can possibly do auto calibration like we do to correct that loose pin and the bushing problem. We gotta have haters out there guys. I always suggest go run an I dig system or something before you fly out to us. Would you run our system? You will be purchasing it before you leave. It always happens but not everybody likes the best and/or will find any excuse not to pay the difference 3172100220
fourwheel1
Millersburg ohio
Ok I'll chime in again here.. Our kobelco had 3/4" slop on 4' bucket at the teeth..I measured this because it was always thrown out as the reason it would rise or not stay on grade. Machine is greased every fuel up and twice on hot days. Pins and bushings have been completely redone on stick last year. The auto simply isn't auto. Don't waste the money on auto. I'm definitely not a hater, I would like my investment to work as good as possible and do what's supposed to. It will dig very accurate but takes a careful operator paying attention. I welcome anyone in Ohio to come run it and see it in action.
IDIGBEST
noblesville, IN.
excavator
I bet you're not doing it correctly. Tell me how are you engaged and what u do with a different controls. I 90% of the time when people have problems with holding cracked fast grade they are not properly working with the system controlling it with their joysticks correctly. Also, like a sharp knife the dollar teeth are the more your actions she can throw off I'll bet if you took the time to give me a phone call would be writing great post. I have seven day a week help if you don't give me a call again. You've never ever asked to help with any of your problems.
Brandon woodward
Indiana
I have an idig and am selling it to go to a 2d system that is a little easier to operate and has some better support. I had mixed results but overall it was more good than bad with the system. I put in septic systems and some field drainage but also do demo with the same machine so switching to a wireless sensor system.
fourwheel1
Millersburg ohio
What part of system are u looking for easier to operate??
