eastroad
I ‘m working on a 212 grader s/n 9T 4728. One precombustion chamber is separated; probably by ether being used to start it, as the pony engine is not operable. The engine was swapped at some time in the past, but the serial number tag from the engine was lost . It is NOT a 9T engine, as the original engine is here, and the pre chamber in that engine is larger than the busted one. I have a 9T1-up parts book and they all use the same pre chamber. I may have to braze this one back together, but if I could identify the engine that was swapped in, I might be able to find a good part, or at least get the correct gasket and o-ring to put this one in after I braze or get it tigged back together. There is a casting number on the cylinder head under the rockers that appears to be 4F1599, but the nines kinda run together and might be 6’s or 8’s. The casting number on the block, lower left side is 3H9069. There are other parts with numbers, but I don’t know but they may be common to many engines. If anyone has a way to determine what the head or block numbers are specific to, that might guide me in identifying what I need.
I did join ACMOC and looked through the books they have scanned there, but I did not find what I need, but I’m not done looking.
I will be grateful for any help.
Oliver Durand
Odie
Oliver Durand
Odie
