Hyster H50XM transmission slippage
Discussion in 'Forklifts/Telehandlers' started by Deon, Apr 8, 2018.
  1. Deon
    Deon Senior Member
    Jul 25, 2010
    760
    Nova Scotia, Canada
    It's a 1994 model. Forklift just came back from the forklift mechanic but he is a Nissan guy, not use to working on Hysters. After new transmission oil and filter it now slips when trying to drive up a ramp when machine is cold but no longer slips when warmed up. Did not do that before fluid change. Could he have used the wrong oil to cause this. Some Hyster models use J20C spec Deere oil. Does anyone know if my H50XM uses the same oil?
  2. tomo
    tomo Member
    Apr 2, 2013
    9
    Illinois
    J20c is the correct oil. Clutch packs might be worn out if you notice it in one direction. The old oil would of had more grip to it from the broken down clutch materials in it. I would test the pressures. Hope this helps.
  3. bunkclimber
    bunkclimber Active Member
    Jul 29, 2009
    44
    MD
    I have two 1990 Hyster h40XLM diesels and all I run in the transmission is J20C spec oil..hope the mechanic did a flush out of the trans..but it sounds like you might be headed for a trans rebuild..not too hard to do once its on the bench..the labor hours are in the extracting from and reinstallation into the lift itself..both my XL machines drop into gear and pull cold or hot..slippage leads to more slippage..fix it now and save money,let it go and pay dearly as more parts will get damaged as you go..if it goes in one direction,the pump is OK, but its sounds like a clutch pack job or trans spool valve issue.might want to check the top of the trans where the valves are and see if the shift linkage is pulling or pushing the control spool valve fully into place..maybe needs some adjustment.FWIW
  4. gtermini
    gtermini Well-Known Member
    May 29, 2015
    150
    Development Engineer (Building research equipment)
    Amity, OR
    Pulling the trans is the hardest part, but nothing too miserable once the mast is off. Ditto on the JD20C oil.
    [​IMG]
  5. bunkclimber
    Jul 29, 2009
    44
    MD
    thats gettin 'er done..easy access to everything..I have a valve body job to do on one of mine..
