willie59
Pardon my ignorance, but are the check valves you guys are referring to contained inside the valve block? Meaning do I have to pull the all the individual block assemblies apart to get to them?
Also, in normal power mode, when I try to raise the boom or curl the bucket, I do get flow through the hose from P4 to Z which indicates the check valves are not working. I pulled a few hoses off today and did see some black residue that could be the left overs of an o-ring. I also spent some time spraying the stuck rollers with oil to hopefully free them up.
With the help from you guys I am slowly making progress.
First of all, there's no shame in asking questions when your seeking knowledge of something you don't know. Asking questions is one of the ways you learn.
Two of the check valves in question are within the manifold. When you look at your schematic, notice all of the control valves and assorted goodies look like they're inside a rectangular box. The box is the manifold. That means anything you see within the box is inside the manifold. But now it could still be a cartridge type valve (like a relief valve in apperance), which you can remove from "the outside", but the valve is still technically "inside" the manifold. There is another check valve, one that is shown outside the box/manifold, the one that goes from the Z ??? port to the P4 port. Now that one should be an external valve outside of the manifold, mabey in-line in a piece of piping.
Let me make sure I understand you. Are you saying that you could take the line loose from P4, leave the port open, lift the boom or curl bucket, and oil would come out of P4. If so, that definately indicates you have a problem with that check valve.
