Well gents...the saga continues. Thanks for all the great insight and I'm actually feeling much more comfortable that I somewhat understand the system and I'm pretty sure my no turn problem is related to the motors crossing over between pumps... which means the manual and my note are wrong BUT before I can prove that, I have confirmed that the brakes are NOT disengaging by;
confirming that the brake solenoid is getting power.. but no oil pressure or flow is getting to the brake release ports on the motors. I pulled the solenoid, cleaned it, bench tested it and it worked.. meaning the spool moved when the coil was powered up. I re-installed it, tried it again and still no flow . Thea solenoid continued to get hot & leak through the case so I figured- bad solenoid.
I called Komatsu to get a new one... and they said the part number in my parts book is invalid, it may not be available and they said they would research it but they never called back. SO I pulled the MFG part number off my "bad" one and after much research, I found a very similar one locally at a supply house. By very similar I mean -same manufacturer, same base part number, same body, same dimensions, same function (3 way - 2 position) same voltage, same connector... but the komatsu version has a diode in the coil and this one does not and there is something "proprietary" about my exact part number that belongs to Komatsu and they would't tell me what it was BUT... as far as the MFG was concerned, the alternate I found "should" function exactly the same but for a possible voltage spike back fed to the wiring when the coil de-energizes. I bought it and installed it... no change... still gets hot - still not output pressure.
SO- I got out my pressure tester, fashioned the appropriate adapters and tested pressure out of the pump into this 3 valve manifold. 375 PSI which was in spec. Reconnected the line and tested pressure out of the solenoid output port. 0 PSI energized or de-energized... no output. so I pull the solenoid and as soon as the screw thread releases, the solenoid shot out under pressure (there is an accumulater on the manifold block).
SO -I pull the output line at the brake motor and using compressed air, blew it back towards the manifold (with the solenoid removed) and the line is clear. I started the engine and oil shoots out the solenoid hole.... thats clear. I put the new solenoid back in, tighten it up and retry the output test and again- no output pressure. I re-verify voltage... it's 14V. SO it would appear the solenoid is NOT opening??? BTW- i confirmed the solenoid is rated to work unto 650 PSI. on ports 2 & 3 (work, pump) and 50 psi on port 1 (return). I suppose there could be something structurally wrong inside the manifolds solenoid bore but WTF am I missing? Tomorrow i may check if perhaps the tank return is getting pressurized above 50 psi?
there is no manual override on the solenoid or would have tried that.
thoughts?
