NCPIPELINE
We have a 2007 t190 closed cab. The machine keeps giving the warning of hydraulic fluid overheating and shuts off, have to wait 30 minutes to continue. Any ideas?
Check cooler first. Also check the cooling fan is kicking on to high. Start the machine and flip the cab. The fan starts on low. Unplug the coil on the fan motor. It should kick to high. If it does not, the valve is bad.
What just about to say that...If it's a mechanical fan, check that the belt is tight or even there. I've seen an idler seize and cut the belt.
There's a filter on the fan drive motor circuit alsoOk been letting it run for a while, went back out and the fan kicked on HIGH as I was standing there... So I am going to change the main & secondary hydraulic filters as well as the case drain filters, and will repost back, I guess if this does not solve the issue it is either plugged cooler or temp sensor?
