tsmallwood
I have a Kubota SVL 75-2 that I just changed all the filters and hydraulic fluids about 50 hours ago. We were running one of our attachments when I noticed a lot of fluid leaking around the shaft we finished up our job and put up the equipment. I pulled the hydraulic motor and took apart the case, I found the bearings had gone out causing contact on the walls of the motor, and causing the seals to leak. My question to you guys is after tearing down the motor, I found small pieces of metal in the motor (looks like aluminium glitter) do you think the filters on the machine would catch this before it would have gotten to the pumps and drive motors. What do you recommend doing. I called a local Kubota shop and they tell me the filters will catch most everything before any damage could happen and not to worry.
Any ideas or experience with these type of issues.
