Hydraulic cylinders dump truck.
Discussion in 'Trucks' started by Willie B, Jan 23, 2022.
  1. Willie B
    Willie B Senior Member
    Jan 2, 2016
    3,494
    Electrician
    Mount Tabor VT
    My Heil dump body, probably built 1975 has two stage hydraulic cylinders. The part number is AID or ALD 2039-1
    In dumped position it does not leak & would stay up months. In down position it leaks out the breather. I'm of the belief the pressure seals the piston, but when pressure is released, it seeps past the piston.
    Hydraulic repair shops are understaffed, overloaded with work. The wait seems forever. Most promising is a shop in next state, a one man shop. He makes promised of "a few weeks turnaround". I think I can handle the rebuild, but a seal kit is at best a maybe.
    I googled it, Found a company Allegany York, they offer a kit for Heil cylinders. Surely, there is more than one variety cylinder for Heil dump bodies? Could it be? The seal kit RH-K272-4893 Faceless.jpg
  2. Old Doug
    Old Doug Senior Member
    Oct 16, 2013
    3,344
    Mo
    I have good luck just taking the seals to a place that rebuilds cylinders they can match most any thing up.
    Delmer likes this.
  3. Labparamour
    Labparamour Senior Member
    Sep 6, 2013
    631
    Washington
    Agree.
    Several hydraulic hose/cylinder shops have helped me with seals and packing for an old Melroe bobcat hoe and a Deere cylinder packing, wiper seals, etc.
  4. Tenwheeler
    Tenwheeler Senior Member
    Dec 15, 2016
    830
    Georgia
    Look into Hercules sealing products and the Red Book. I would take them apart. Measure and order the seals. Hopefully that matches your part number. No telling if those cylinders were replaced over the years.
    Jonas302 likes this.
  5. SoCoHyd
    SoCoHyd Member
    Oct 29, 2020
    6
    Houston
    How much oil is leaking out ? unless its a considerable amount, I wouldn't even worry about it. if you think it's just the bleeder then remove the bleeder and change it out. no need to pull the cylinder and have it resealed because of a bleeder. But considering you said that it doesn't leak down at all when in the up position then it's most likely not the bleeder.
    you might just be confusing oil accumulation on the rods and caps as an oil leak from the bleeder. Telescopic cylinders allow for a film of oil to accumulate.
    of course I can't confirm this without seeing it
    but for some piece of mind here is a quote from a reference guide on telescopic cylinders provided by Hercules Sealing Products
    "A damp to light film of oil on each plunger or stage of a telescopic cylinder indicates good cylinder operation. After many cycles of the cylinder, a small accumulation of oil may be noticed on the plungers or sleeves at the head nuts. This should not be mistaken for packing leakage. Cylinder should be free of entrapped air. It is advisable to bleed air from cylinder weekly for a smooth operation."
    this quote, along with other information, can be found @ this link. click on the "Technical Information" tab which will open a PDF and it will be on page 7 of the PDF (page number of the article will say 559) https://www.herculesus.com/page.php?name=Reference-Guides&id=306
    here's the direct link to the PDF although im not sure if this link will work. chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/viewer.html?pdfurl=https%3A%2F%2Fwww.herculesus.com%2Foracle%2Ffiles%2Freference-charts%2FTech.pdf&clen=845279&chunk=true
    DB2 and 59 North like this.
  6. SoCoHyd
    SoCoHyd Member
    Oct 29, 2020
    6
    Houston
    If you still feel like your cylinder needs to be taken to a shop to be resealed be wary of what they will charge you for reseal/repair. I wouldn't pay more than $1000 to repair a 2 stage telescopic cylinder.
    If its a generic cylinder with no extra features you can most likely buy it brand new anywhere from $1200-$1800
    here are some options. https://www.baileyhydraulics.com/pr...escopic?order=onlinecustomerprice:asc&show=48
  7. Willie B
    Jan 2, 2016
    3,494
    Electrician
    Mount Tabor VT
    Leakage is perhaps a pint from each after being dumped. I generally leave it parked body up to drain rain or melting snow. No leakage. Leakage happens body down at rest. When I tow, I can't raise the body, so it leaks.
    The above mentioned seal kits are described as being for Heil cylinders. I'm perplexed at a kit so non specific.
    How does one bleed air from a cylinder? How does air get in? I expect air above the piston, but below is perplexing.
    No, the site wouldn't open.
  8. SoCoHyd
    SoCoHyd Member
    Oct 29, 2020
    6
    Houston
    oh well that definitely sounds like a leak and not just a "light film of oil" haha.
    I'm pretty sure that cylinder part number you gave that starts with "2" indicates it's the "old style" Heil telescopic cylinder which means this cylinder is going to have "vee packing." Vee packing reacts to pressure so you're right on the money when you were talking about leakage when pressure is released.
    Before you pull the cylinders you might try tightening the 2 gland caps with a pipe wrench and run it up and down a few times. If that doesn't work then pull the cylinders and do the reseals
    Air can get in these telescopic cylinder from the negative pressure they produce when retracting as well as when they are being installed after a reseal. It should have a breather at the rod eye. it will most likely be a bolt that you would loosen until oil starts coming out.
    Tenwheeler likes this.
  9. SoCoHyd
    SoCoHyd Member
    Oct 29, 2020
    6
    Houston
    Can I ask how you determined that seal kit part number ?
    I just took a look at the seal kit number you gave and it shows that the seals in this kit are "u-seals" as opposed to "vee packing"
    I don't think Allegheny sell kits for Heil Dump Truck Cylinders. I think the seal kit number you gave is for a telescopic cylinder off a Heil Refuse Truck.
    Another reason I think its Vee packing is due to the age of the truck as well as I've found vee packing to be the norm in Dump truck cylinders
    I would call Allegheny and make sure the kit is for a dump truck cylinder
    If it is Vee Packing
    Hercules Sealing products has Heil Vee packing kits
    https://www.herculesus.com/product.php?name=Special Heil Telescopic Vee Sets&cat=16530
    part number for the 3 -1/4 " stage is "HL26A2039"
    part number for the 4" stage is "HL40004X184"
    I hope I was able to help and if not good luck !
  10. Willie B
    Jan 2, 2016
    3,494
    Electrician
    Mount Tabor VT
    Thank you so much for your contributions. The Allegheny website brings up this part number when I googled the cylinder part number. I'm not convinced these will fit. Website says $190 per, but I Emailed them, she says $80 per.
  11. materthegreater
    materthegreater Well-Known Member
    Jul 25, 2012
    235
    VT
    Willie, how did this turn out?
    In testing my dump hinges today, I discovered that the "not leaking" used cylinder I bought leaks oil out almost as fast as the pump can get it in there. So it looks like I'll be tearing the cylinder apart and trying to find the problem.
  12. Willie B
    Jan 2, 2016
    3,494
    Electrician
    Mount Tabor VT
    The valve used is not the detent style that locks in the down position. Put a bungee cord on the handle to hold it in down position. It no longer leaks.
  13. 56wrench
    56wrench Senior Member
    Dec 4, 2016
    1,433
    alberta
    I never store a truck with the hoist in the raised position because it exposes the cylinder to dust, rain etc. i only raise it about 1 or 2 feet, enough to let moisture drain out of the box. Dirt and moisture can work their way through the wiper as it is lowered as well as the upper stage/stages can rust if left exposed if the wiper is doing its job
    doublewide likes this.
  14. materthegreater
    Jul 25, 2012
    235
    VT
    Sounds like an easier fix than mine will be!
