still learn'n
Is there a way to test if the starter is bad when it is still on the machine? The case is on a RM500 with C15 motor it wudnt start cuz the batteries appeared to be low voltage! I jumped it and got it started and then it happened again so replace batteries! then the volts was still getn jerked out of the batteries sumhow! yesterday went to get it and it wudnt start hooked a grader up to it and left it on for 20-30 min and still wudnt the jumper cable were getn hot like it was pulln lots of volts! could the starter have short in it that wud be pulln the batt down? btw it was in the 20's yesterday so was cold to! Thanks Jerry
