how to set timing on the balance shaft
Chicken
Florida
I am looking for information on how to set the timing on the balancing shaft on a JD 2640 or JD 239 engine
mg2361
Pennsylvania
Equipment Mechanic
See attached. Ignore the model numbers. Balancing is the same on all JD engines. Can use a straight edge instead of special tool.
  • Balancer timing.pdf
  • Install and Time Balancer Shafts.pdf
