1968 Case 580CK
Ladies and Gentlemen......and expert rim/tire guys:
As you can see in these pictures, I have two old 1968 580B CK rims which are in good shape except for rust-out around the valve stems. Do "they" make a metal patch that will fit over the contours of the rim which can be welded in place? Then, just drill the right size hole for the new tire tube valve stem? If not, any suggestions as to the best way to do a repair on these rust spots?
Thanks!
Thanks!
