69zfarmer
I am pretty sure my right track adjuster is leaking grease causing track to be loose. I cant see the leak but there is grease everywhere in the access hole for the grease zerk. The zerk is not leaking. I pumped it up yesterday and the idler assembly moved back about 1/8" in 24 hours with the machine just sitting there.
I know you have to remove track and idler assembly to get to it. But then how does the cylinder come out to repair it? I don't see any bolts holding it in. Please Help!
