Bls repair
You could put an oak plank on the ramp from over the leg to top of taper . This should keep the ramp from kicking out. You should cut a taper on both ends of the plank so it would easier to get on and off of plank
I will have to check that out and maybe weld some chain. Many people do not understand his situation as I would not have before I got in a tight spot. While loading a IHC 1066 and a 10' rotter tiller on a trailer like that I experienced a problem. The ramps which extend directly below the pins flipped up as the truck slid forward. Movement stopped when the trailer tail hit the ground. When I tried to pull forward weight was removed from the tail but not applied the the truck to prevent rolling down hill. Actually just a slight down grade but at the top of a good down hill. Also found the combination and angle touchy. Decided to just go for it as the weight transferred forward the truck would stop it. Then the front tractor tires wanted to become air born and run off the right side of the trailer. If I backed up the ramps would destroy rear panels on the tiller. Toys compared to td25c's stuff but lumber is cheep in comparison to accidents. Loading and unloading a 680CK on the same trailer is never a problem.
