Valve Adjusting Update and Tricks:
Well, I managed to adjust all the valves with no issues. I was right about the rear valves having bit of a loud "clattering" noise. When I checked cylinder No. 4, the exhaust valve was set at .022, and the setting should be only .014, so it was way too loose. All the others were a bit off, but not as bad as the No. 4 cylinder.
Here is a pic of the viewing hole where you match the pointer up to the Top Dead Center mark:
I had someone bump the starter button as I was underneath the tractor looking for the TDC mark. The marks come in increments of 10 degrees, starting with a 30, then 20, then 10, then the DC mark. I found it was easier to just take a large screwdriver and once I was close to the TDC mark, I found bolt heads or other nooks in which to wedge the screwdriver and slowly turn the flywheel to the TDC mark. (This was alot easier than taking off the starter and using the flywheel teeth). I tried putting pressure on the fan belt and pushing on the fan, but it would not get enough friction to rotate. The belt was a bit loose, and already on the outer most point of the adjustment. Fortunately, the screwdriver through the viewing hole did the trick.
Questions for the experts: Here is a close-up pic of the rocker arm where it rubs against the valve head. All of them have a "rounded-off" rubbing area on the rocker arm. Is this the way they come new, or just from rubbing-away over the years?
Another question: Here are a couple pics of the valve adjusting screw. At first I thought there was an allen head screw on the top of the rocker, but it turned out just to be a hollow screw, and the adjusting screw was a 1/2" nut on the underside of the rocker. In my experience, there has always been a way to "lock" the nut after you adjust it. In this case, all I found was the nut and no way to lock it after the adjustment was made. It did turn with alot of resistance, so I guess the threads are lined with some type of locking material to keep it from moving. Can anyone explain if this is the case, or if I am missing something?
If someone doesnt have a shop manual, here is the one page instructions:
(will post in next section, as I think I am out of pic room)
