How far can an excavator be driven
Discussion in 'Excavators' started by Ne farmer, Aug 9, 2019.
  1. farmerlund
    farmerlund Senior Member
    Nov 22, 2014
    963
    Farmer/ excavator
    North Dakota
    That sounds like a lot more abusive conditions John C.. How many hour does the UC last on some of those machines?
    Sounds like mine has an easy life cruising the township roads and farm fields.
    DMiller likes this.
  2. John C.
    John C. Senior Member
    Jun 11, 2007
    11,726
    I've seen some get less than 2,000 hours in the early days. Now I see excavators do 3k to 4.5K on a set of chains and able to do two sets of chains per one set of rollers and idlers. Last time I was around loggers you could see 3.5K for the whole undercarriage. Haulback might be able to give a better idea of what's happening now. I think he still has a shovel logger or two.
    DMiller likes this.
  3. Skeans1
    Skeans1 Well-Known Member
    Jun 25, 2018
    82
    Rainier, OR
    In the thinning with a track buncher/harvester running a D5 undercarriage on a 40k machine we’d see 3500 to 4k with single bar grousers in an application where you’re always bouncing off of stumps.
    DMiller likes this.
  4. Oldcatpusher
    Oldcatpusher Well-Known Member
    May 29, 2019
    162
    Arkansas
    I have 4100 hours on my hoe. Rails are shot. Lots of walking across job sites, land clearing, sometimes I'm on solid rock running a hammer. Hasn't had an easy life. I have a few slightly bent pads but rollers and idlers are all in great shape. Sprockets even look brand new still with hardly any wear except for a few chips gone off the corners. I've been debating whether to take a link out and run them till they break and try to tough out the bouncing that comes with worn rails or to replace the bent pads and put a set of sealed and lubricated tracks on. Adjusters are maxed out and tracks are starting to really sag. Any input?
    DMiller likes this.
  5. John C.
    Jun 11, 2007
    11,726
    I've looked at lots of machines where a link was removed. It will work fine as long as the roller flanges are not riding on the track pin bosses.
    As far as using SALT track on excavators, I've never seen it done. The problem in my mind is that excavators put weight to the links and push them apart over time. If you look at the joints on old tracks you will see the big end of the links have pushed apart. SALT track has seals in that joint and if you push the outsides away from the trailing link the seals will lose their contact and leak.
    DMiller likes this.
  6. Oldcatpusher
    May 29, 2019
    162
    Arkansas
    Thanks for the info. The rails haven't worn much on the part that rides on the rollers and are nowhere close to hitting the pin bosses so I may just have a link took out. For some reason I thought you could use Salt tracks on a hoe
    DMiller likes this.
  7. farmerlund
    Nov 22, 2014
    963
    Farmer/ excavator
    North Dakota
    Would be interesting if they had a miles traveled meter. Maybe some newer ones do. My volvo 210blc has 6,000hrs on it. Still has original UC on it, and I will get probably get 2,000 more out of it easily. Obviously mine is a trailer queen compared to logging and other applications.
    DMiller likes this.
  8. Shimmy1
    Shimmy1 Senior Member
    Aug 14, 2014
    3,346
    North Dakota
    My Case has a log of hours traveled in low and high. A guy could probably come up with a reasonable estimate of miles traveled.
    DMiller likes this.
  9. Skeans1
    Jun 25, 2018
    82
    Rainier, OR
    I looked in the wheel machine today at 2360~ or so hours it was over 500 miles.
    DMiller likes this.
  10. John C.
    Jun 11, 2007
    11,726
    I think I might be able to be calculated but there is nothing in the finals that counts revolutions. Nothing like in a transmission that can count turns of a gear or shaft.
    DMiller likes this.
  11. Oldcatpusher
    May 29, 2019
    162
    Arkansas
    What kind of case hoe do you have?
    DMiller likes this.
  12. Former Wrench
    Former Wrench Senior Member
    Jan 3, 2014
    405
    Retired
    Montesano, WA
    I would go back to the use/abuse line theory. Walk it accordingly. Are you covering shot rock, sand, field dirt, pavement, and so on? Don't get it bouncing and causing a bunch of stress that could lead to cracks. Take your time.
    DMiller likes this.
  13. Shimmy1
    Aug 14, 2014
    3,346
    North Dakota
    210C
    DMiller likes this.
  14. Oldcatpusher
    May 29, 2019
    162
    Arkansas
    How do you get it to pull that up? I have a cx210c and cx160c both 2015 models and I can't get the machines to even switch the auxiliary hydraulics from crusher to hammer mode on the monitor. All I can change is the flow amount.
    DMiller likes this.
  15. Shimmy1
    Aug 14, 2014
    3,346
    North Dakota
    You have to go into menu mode and setup the aux hydraulics. In setup, it will make you warm up the oil if it's not warm enough, then you set what pressure you want, then it will prompt you to hold the aux hydraulic control until it finishes its calibration. I have mine set at 2900 for my thumb, and 4500 for my tilt bucket. To get to the data log, you have to go into diagnostic mode. I can't remember which buttons you use without looking at the screen. I'll look tomorrow.
    DMiller likes this.
  16. Numbfingers
    Numbfingers Well-Known Member
    Oct 28, 2016
    136
    mechanic
    Alaska
    We walked an old CAT 225 and a older Komatsu dozer out of a mine 34 miles to the road a few years ago. Nothing bleeding oil when we were done.
    JPV, John_8791, DMiller and 1 other person like this.
  17. Shimmy1
    Aug 14, 2014
    3,346
    North Dakota
    Sorry, guys. I don't run in turtle, lol. IMG_20190815_105555655.jpg 2019-08-15 10.58.29.jpg
    I also don't run in "A" mode very much.
    DMiller and Wytruckwrench like this.
  18. farmerlund
    Nov 22, 2014
    963
    Farmer/ excavator
    North Dakota
    that's a cool page Shimmy. looks like your using the power boost also :D
    DMiller likes this.
  19. Oldcatpusher
    May 29, 2019
    162
    Arkansas
    I'm going to try to find that tomorrow. Definitely never seen that page on mine. But I'm still finding out stuff if does all the time. Had it since new and just found the aux plug in the other day for the radio 4100k hours later.
    DMiller likes this.
  20. Oldcatpusher
    May 29, 2019
    162
    Arkansas
    You've got me beat on power boost time shimmy. But I still can't get my attachment to switch to hammer mode. I had no clue you could look at all that. Last time I put hammer on I called the case dealer to come flow test machine and the mechanic told me my monitor was out is why it wouldn't switch over. He only brought a 3/4" flow gauge that went to 32gpm for a 1" line. I called dealership and told them how highly disappointed I was. Never got charged but never got what I asked for.
    DMiller likes this.
