no good reason not to drive it that little distanceI need to move my 200D. How far do you drive an excavator? I need to go 1.5 miles.
CM1995 is correct on the direction. It makes a big difference on wear on the sprockets and track bushings.
I'm curious if you have any real life examples where there is a substantial, measurable difference in life of the spockets and bushings, and what the actual difference in hours is. For example, two identical machines doing the same work, only one always spun his tracks around to travel forward for any measurable distance, and the other just went with the flow. Not disputing at all that you get more wear in reverse, I'm just also in the camp that doesn't think it matters as much on an excavator as a dozer. If you are consistently walking the machine several hundred yards or more in one direction on a daily basis, then I'd say yes, you should be keeping the idlers pointed the way you're going, if practical.CM1995 is correct on the direction. It makes a big difference on wear on the sprockets and track bushings.
Lol. So you're saying you've *never* backed up a bit by using your toes to push the pedals rearward for reverse?? I know I have, and it's much easier than using your heels.Plus it easer to push the pedals forward with the front of your foot for 1.5 miles instead of using your heals.
