Dirtguy, if you are talking about some of the new scrapers where the bowl lift cylinders have a cushion effect, I expect they work on a similar priciple to the nitrogen/hydraulic system on Cat cushion hitches or Terex suspended front axles, similar in construction to what is described above. A lot of newer wheel loaders also have a system like this for the loader lift arms, to reduce the tendency for the machine to "lope' during travel mode.
As best as I understand it, picture a selaed cylinder where the piston floats in the cylinder. Nitrogen gas above the piston and hydraulic oil under it...really like a big gas shock absorber. When the selector lever is placed in the locked down position, they oil is bled off and the cylinder compresses and has no cushion effect. When the travel mode is selected pressurized oil lifts the piston part of the way up the cylinder and nitrogen is in the space above it providing a cushioning affect. It's going to take a Cat mechanic to explain it better than I can..
From what I've read, Cat 627H series and Terex TS14G or current models have this priciple applied to the bowl lift cylinders also.
Hope this helps somewhat....I ran a 621G for a short while but generally I run 621/627 B models from the 70's and 80's, so I haven't been around the new stuff too much yet. And Terex is a bad word as far as scrapers are concerned around here (Nebraska, or at least my part of it!).
Alan
