digger242j
Obviously, this question won't relly be pertainent to some of our members from the more tropical climates, but this week it sure seems pertainent to me--Do you have any sort of standard as to how cold is too cold to work?
Last night the low temp here was forecast to be 7 degrees, and the high was forecast to be 18. The actual temps recorded were a low of 12 and a high of 20.
For the snowplowing, and coincidentally snow shovelling, that I'm involved with, the contracts have language that reserve the right to pull off the job if wind chills are below zero, although I don't recall that ever having been done.
I once worked for an excavating contractor who had a rule that if it got below 10 overnight, and it wasn't forecast to be above 20, it was too cold to work that day. Today's forecast weather would've met that standard, although the actual conditions turned out to be better.
What I had to do today concerned a mudslide that was threatening to involve the driveway, and the underground electrical service, of a *big* (read: "awfully expensive"), house we worked on a couple years ago, and it was going to be done no matter what the temperature. Given my choice, and the forecast, I'd have probably found some inside work to do instead.
Do any of you have a "standard" for what's "too cold" to work?
