Hough 50 straight frame
Needs a pump, or a rebuild kit. 2 of 4 bushings cracked and allowed out of center rotation which chewed the shaft. If I can't find parts reasonable, ill build up the bushings, and lathe the shaft to fit.
Only #s I can find on the pump look like casting #s. Unless those are the numbers I need.
Its a 3 sp with shuttle shift.
The auxiliary is setup with a flange to bolt on something besides a pump for different application I'd imagine.
It had a 6cyl diesel, then a 6cyl gas. Now a '64 high compression Chrysler 318. Yes, custom bellhousing adapter. And its got plenty of grunt.
The drott 4in1 clam spoiled me clearing this field of trees. I feel icky using a straight bucket....
Anyways any more info needed just ask, ill provide whatever I can find on the machine. I'm not sure what pumps were common on this model machine. Its a gear pump.
Thanks, jason
Sent from my PC36100 using Tapatalk
