datsunman
HI, Im a proud recent buyer/owner of a HOUGH Payloader but I can't find the model plate or identification on it. I did find a tag on transmission with the following- Rockwell Standard corporation HOUGH 123111 SERIAL NO 2 83-0016
The ratio is not completely clear (1 ??2-10) or (1 182-10)
This tag was on the right side of transmission case and made of aluminum riveted on stamped letters blackened with blue in the letters.
This is a 2-speed + forward/reverse.
I also find that it has a torque converter between clutch and eng which is Waukesha model(FC 3.25x4)No38154 G5843,gov speed 2000loaded RPM
torque converter is stamped (43) on the top next to oil fill/dipstick/breather
Clutch bell housing has cast in tag (235-L) and cast in lettering(4887 S 123) Also a circle around the Capitol case B, folowed by a lone D
Also a number tag in the top of bellhousing of torque converter facing the engine and close to starter(341-L
This is all the info so far and I hope that one of you can help me find or determine what its model would be. I want to find and buy repair/parts/operator-manuals for it. Your discussions about these helps me because mine has 2-lift and 2-dump cylinders. I really need engine rebuild parts and the trans had a lot of metal shavings in the gear-oil and one of the cast driven hubs is cracked badly. I can set up pictures to show here soon.
