Snuffy2
Good morning "Greenblood", I also have a Hough H65C. If you look at post# 17 you will find the filter number that I used (BaldwinPT386) I hope this works for you. The other thing you mention is the transmission sluggishness, I also have the same problem. I find that it takes about three minutes of running before the unit will move. The problem my be the torque pre-charge pump. As far as far as the fluid level goes, I check mine with the engine warmed up and running-loader sitting flat and level. I changed the fluid and filters , cleaned the screens (both) and the transmission did work better but third gear still slips a lot. This loader is used to move dirt on the farm so I make allowances. My pins and bushings are loose so I am in the process of trying to locate a good parts source. I hope this helps.. Thank you.......Jim
