Different fuel pressures, depends on how the propane regulators are set up..... do you have a regulator at the tank, and a demand regulator near the carb?
It was a shame to see a lonely forum
I don't see a heated regulator.
Pictures before we do any more speculating. Or at least some model numbers off the regulators and mixer (carburetor). There are only a handful of fuel systems out there for gaseous fuels and once we know what yours is it will be pretty easy. Propane generators are my specialty.
I'm not sure if you could post an actual video itself on here but you can definitely put the video on youtube and put a link to it on here.[/Q
I tried a few things today and have it narrowed down to the 100 lb tank shutting off because of the flow control valve in the end of the hose that connects to the tank. It appears to have a check ball that prevents excessive flow for safety reasons.
Engine will run ok with the tank valve slightly cracked open, but starts to hunt with no load. If the valve is opened more then then engine quits because the valve closes.
Does that sound right?
