Anthony Friot
I have a 1/4 mile driveway. I have plans to screen my own rock from the spoils of digging our pond. If I cannot get enough rock...my pond will get deeper and cover more area. I'm looking at 3/4 acre up to 12 feet deep. I want to build my own jaw crusher and I would appreciate some guidance from those who understand metal, rock and that there are people out here that just want to do things ourselves. I know the basic design theory, but am quite unsure of steel types and sizes required to break rock. I have collected a variety of tools and metals I think might help me build a crusher. I know I probably should use manganese jaw plates, but they are not easy for me to find used in the size I would need. I also don't believe I could afford new plates even if I knew where to buy them. I have tries to contact a couple companies who say they make them, but being a little guy, I don't get a reply.
I should have a power plant that should be more than adequate for what i want. I have a 6.5kw diesel generator capable of 3 phase, a 40 HP 4 cylinder power plant with clutch and 3 belt pulley and a 35 HP hydraulic power plant. For materials, I am thinking I should be able to do something with large loader forks. They are 12" wide and maybe 10" deep. It's hard to explain them so I'll just show you.
I thought about using the two pieces I cut off to operate together to crush rock, but then I thought that one of the sections I left attached to the rest of the fork was already fastened well to a solid structure and could make a great plate to push (gyrate?) against. I believe I need to make an eccentric shaft to give a circular motion to the movable jaw. How mych movement is required and how many rpm should the machine operate. I'm sure there is a sweet spot...maybe for every machine it might be different.
If a hollow jaw isn't ideal, could it be filled with concrete to give it a firm back to push with? But then I have to think how can I crush rock with concrete. If filled, the concrete has nowhere to go as it is again reinforced by the 1" steel on three sided.
Also, I have a piece of steel that is 4"x9.5" solid by 8' long to make jaws with. Maybe even the eccentric shaft as well.
I know that even though it is solid, it may be soft steel and unusable. How do I find out if it's good to use. If so...how do I cut it? I already know that the forks I can cut with a torch as it is only 1" thick about it's perimeter, but I don't believe I have a way to cut the 4"x9.5" steel to length. Maybe make a power hacksaw and connect it to my inverter to let it run until it's through. BTW, I'm totally off-grid. No grid power.
I watch Youtube videos of homemade jaw crushers, but I don't see many rocks being tossed into them. Concrete isn't nearly as hard as stone. Until my driveway and foundation are finished, I want to be able to crush stone as I need to. I don't need to do it nearly as fast as commercial crushers and I don't need to spend the same money to do it.
I have to step away from the computer for a bit. Clear my head and change a tire on the backhoe. In a few minutes, I'll have 4 new tires. Courtesy of my wife. She really wants a new house! Can't blame her, we need more room and a door for the cat.
I left a preliminary image for the crusher I made in sketchup.
Thank you and see you soon.
