Homemade drill drive boring bars
Discussion in 'Shop Talk' started by steve loving, Jul 30, 2011.
  1. steve loving
    steve loving Well-Known Member
    Nov 23, 2006
    175
    blountville tennessee
    Here are a few pictures of some bars ive made out of 1045 crome shaft with 1/2" threaded tool ports.
  2. steve loving
    Nov 23, 2006
    175
    Jobs with drill drive bar
    Holes were worn about 3/8" off to one side
      File size:
      56.8 KB
      4,515
      File size:
      94 KB
      4,671
      File size:
      75.7 KB
      4,648
      File size:
      71.6 KB
      4,496
      File size:
      84.4 KB
      4,565
  3. brushmaster90
    brushmaster90 Well-Known Member
    Jul 15, 2011
    49
    independnt tractor operator
    Arkansaw
    Good work man, well done.
  4. steve loving
    Nov 23, 2006
    175
    Drill drive
    The frame on this 6 wasnt bushed from the factory. I didnt pull the pan or converter the hardbar was bushed but the frame wasnt. I bored oversized and installed hardbar bushings in the frame. This was a few years ago and it has held up great
  5. RayF
    RayF Senior Member
    Jul 9, 2011
    637
    lineborer/welder
    Perth Western australia
    Steve,I like that set up with the universal joint boring bar. If you have to do those centre pivots you might as well make it easier. I did a couple of those on a D6,both in the same week.What was interesting was one was an LGP version and the other standard. One had a metric sized pin and the other imperial:confused:
    I remember doing one on a 9L years ago out in the open at sand mine.The track frames were off and the tractor was sitting on 4 stands. Well it was raining heavily and while I was doing the job I could see the stands slowly sinking into the wet sand. I was glad to finish and get out of there:)
  6. steve loving
    Nov 23, 2006
    175
  7. steve loving
    Nov 23, 2006
    175
    Ray i love that small bar ive used it quite a few times. Some old case backhoes had swing towers that wernt bushed. I get a hardend ground bushing for the newer case and just oversize. Ray i worked for a guy for about 2 years named Ian Mundell here in the states he coowned ameraus tractor with the coal miner i worked for. They split ways and he is now back in qweensland selling some parts his web is ironfarmer.
  8. Swamp rat
    Swamp rat Well-Known Member
    Apr 17, 2009
    114
    La / Ga
    Steve , i havent been around boring in person and i was wondering - are you hand feeding the cutter on this type of cutting? Tis type of work has always been interesting but i never had the opportunity to watch any , by the way your work looks great.
  9. 250c
    250c Well-Known Member
    Jul 9, 2011
    110
    Gatesville Tx
    Steve, First I like to say "nice work". Your set up reminds me of a old Kwik Wayengine line boring bar that have it is old nough that it cuts by a hand crank---come to think of it I'm old enough to own it lol.
  10. steve loving
    Nov 23, 2006
    175
    On the d6 i used a 1/2 makita drill and hand feed. I didnt have weld in the bore it was a smooth cut. On the case part the bores i welded the holes so i knew there were going to be some interupted cutting so i used a 3/4 gearhead drill with quick homade carriage.
  11. steve loving
    Nov 23, 2006
    175
    Thanks what did quickway use as far as setting the cutting tool
  12. RayF
    RayF Senior Member
    Jul 9, 2011
    637
    lineborer/welder
    How about a mag base drill to drive it.You can get them 4 speed a well as a variable speed motor and use the handles to feed it ?
  13. 250c
    Jul 9, 2011
    110
    Gatesville Tx
    Steve I'm a techno dummy an couldn't post pictures if my life depended on it. But to answer you question it uses a micometered adjustable bit holder would be how I describe it. You might like looking @ the instructing manual http://www.fordfarm.net/Kwik-Way-manual.pdf ----I doublt those prices are still good lol.
  14. steve loving
    Nov 23, 2006
    175
    Ray i used a fixed speed mag drill on a longstick 322 and it worked good. What ive been looking at building is a pass through design like yours but instead of hyd using a css unitec tube rolling motor its like Tom V's york motor it has a four speed gearbox. Then i like your hoffman feed design. I Think the rpm is 60/90/140/200 I think that would do a good job for what i am doing. Imput welcome Steve
      File size:
      53 KB
      4,234
      File size:
      38.4 KB
      4,260
  15. steve loving
    Nov 23, 2006
    175
    Thanks 250c i will check it out.
  16. RayF
    RayF Senior Member
    Jul 9, 2011
    637
    lineborer/welder
    Those RPM's would work ok.The Hofmann feed units are expensive but a good unit. I'm not sure what else is available.
  17. Old Magnet
    Old Magnet Senior Member
    May 11, 2010
    1,733
    Corralitos, California
    Question for Steve Loving???
    I have one of those old Case swing tower back hoes that needs bushing (530CK w/#32 hoe)
    and I saw your reference to using a later bushing(s)....would take two at the lower pivot. Can you tell me what the Case part numbers are for the bushings I need. Thanks
  18. steve loving
    Nov 23, 2006
    175
    old Magnet i havent done a 530 but my case dealer here keeps his bushings on the shelf where you can look and measure. I have to go pay for some parts in just a few days and ill see what i can come up with. If the tower hasnt got bushings it would be nice to have a length for the bushings top and bottom. Ill be glad to help thier bushings are about 1/4 wall would that be enough to clean the hole up Steve
  19. steve loving
    Nov 23, 2006
    175
    530 swing tower
    Old Magnet D21927 BUSHING is what the upper bushing part # for 32 hoe is. You might already know go to mycasece and hit parts then launch parts catalog and type in model it has the 530 nd your hoe. Hope it helped
  20. TOM V
    TOM V Senior Member
    Mar 12, 2011
    628
    Mechanic, Welder, Office work ect.
    CONNECTICUT
    Steve, good job on the Cat equilizer pivot. Nice boring bars also.
