Hitachi zx225uslc throttle not working
Discussion in 'Excavators' started by Martin Canuel, Nov 18, 2019.
  1. Martin Canuel
    Martin Canuel Active Member
    Nov 16, 2019
    29
    Prince George, British Columbia
    Did a relearn did not solve the issue with not being able to turn off with key.Throttle works however
  2. excavator
    excavator Senior Member
    Oct 16, 2006
    883
    Pacific North West
    I've had them with a bad diode in the alternator not allowing the battery relay to turn off but they were all dash 5 or earlier. I also had a ZX230 that would not shut off with the key, it had a small wiring fire down behind the batteries that melted all the wires in the harness together. The amazing thing was it did not blow any fuses.
  3. Martin Canuel
    Nov 16, 2019
    29
    Interesting.. so this diode in the alternator i assume is not replaceable/serviceable.. has to be replaced with the alternator?
    So check harness to the alternator then?
  4. Martin Canuel
    Nov 16, 2019
    29
    Ive read that welding on the machine can cause alternator diodes to get fried. That being said we just welded catwalks on the machine and a thumb prior to that, we used the night switch as our battery disconnect. Maybe the 2 events are related..
    DB2 likes this.
  5. LACHAU
    LACHAU Well-Known Member
    Aug 11, 2009
    157
    VIETNAM HCMCity
    There are 2 simple ways (very...very...very easy to solve the problem).
  6. Volvomad
    Volvomad Senior Member
    Jul 14, 2011
    251
    Ireland
    Just wondering when you go to turn off does the engine speed drop any ?
  7. Martin Canuel
    Nov 16, 2019
    29
    I was finally able to get someone to shut of the machine while i watched the servo motor. When shutting down the engine you can hear rpm drop/ sputter a bit to a lower rpm. Watching the actual motor it barely actuates the throttle when shutting it down. Iam going to adjust the throttle cable some more manually and see if that solves my issue.
  8. Martin Canuel
    Nov 16, 2019
    29
    OK adjusted the throttle cable while machine was running and took the idle right down to almost a sputter, then ithgtened it up and used key to turn off, barely made the rpm drop when i hit the key off.. engine relearn ? also when i had the servo motor disconnected initially there was about a inch of play in the throttle cable,. when i attach the servo to the arm do i pull out all the slack and tighten it>?
  9. Volvomad
    Jul 14, 2011
    251
    Ireland
    If there is an inch of freeplay in the system (not moving injection pump lever) I would think that is your problem
  10. Martin Canuel
    Nov 16, 2019
    29
    Well after all of that, replace servo motor, pulling interior dash apart to test wiring, testing all the sensors, took your advice and replaced the throttle cable and wouldnt you know it a new throttle cable from servo to inj. pump fixed all my issues!!! I do thank all of you for the trouble shooting help i truly appreciate it and it actually helped me learn alot about my machine.
    mg2361 and LACHAU like this.
  11. Martin Canuel
    Nov 16, 2019
    29
    Well guys its doing the exact same thing again
    1- wont shut off with key
    2- dr.zx wont communicate
    3- no servo sound or motion with key on
    4- must use manual throttle kill to turn off machine
    5- servo motor, throttle cable have been replaced.
  12. Martin Canuel
    Nov 16, 2019
    29
    None whatsoever, when i turn on the key generally you can her the servo motor do a adjustment of some sort, when i have this issue it makes no sound with key on
  13. Martin Canuel
    Nov 16, 2019
    29
    We replaced the throttle cable thought it solved the issue, was temporary. now back to square one doing the same thing again
  14. Couger Chris
    Couger Chris New Member
    Saturday
    1
    Hi, we are going through the same problems on a 225. Did you win?
