Martin Canuel
I have a 2006 zx 225 uslc zeroswing
No communication with drzx pda with machine.
Machine won't respond to throttle dial.
Machine won't turn off with key. Must use manual shut off
I've replaced the throttle motor with a new one and didn't fix it, replaced key/ignition cylinder.
On the 3 pins ec sensor while running at idle I read 4.5v 1.7v and ground. Regardless of throttle position those readings don't change. Also tested the 4 pins on the motor side and
pin 1 is (. 2 to 1.4) fluctuating
pin 2 is (. 2v)
pin 3 is (. 5v)
4 is ground.
Any insight would be amazing I'm pulling my hair out. I've done a relearn probably 8 times doesn't do a thing.
Motor doesn't even make sound now when starting. Randomly will work fine one day then next no response.
Ive tested the across the ec sensor coils as per the tsb about these ec motors as well and 1-2 reads 1.07 and the 2-3 reads 1.18
Bad ecm??
We had a thumb and catwalks welded onto the machine recently, battery disconnect switch was off the whole time. This is also a intermittent issue now was sometimes it will work on startup then no throttle response.
pin 2 is (. 2v)
pin 3 is (. 5v)
4 is ground.
Bad ecm??
