MasterofDiaster221
I got a Hitachi ex35 excavator that got real slow on all the functions hard to even tell a difference between high and slow drive speed. I changed all hydraulic filters,pulled screen out of tank and cleaned it.Went ahead and changed fluid also change the pilot control filter, tank hydraulic filter and cleaned out the strainer bit no signs of trash. Put some gauges on the machine and dead headed each functions and all functions was at the 2800-3000 psi mark and pilots pressure around 450psi. Pulled case drain lines off the machine to check drive motors and there was just a drip in high and low.also checked my pressure when in high speed and was when petal was pressed pilot pressure was put to the line so all is good just wondering if the pressure could be normal but could flow be down?? Once the pumps slowed down the pumps started to whine
