chHart
by the way my email add rein1966.hj@gmail.com
I did the same conversion directions suck and no help. So I printed out all the pictures I could find showing hose routing and pump adapter. Ok got that, then could not find where hose went on valve block. I compared pictures of all the different kits for sale and found one part I didn't have and couldn't buy separately. It is an adaptor to replace DP sensor which is where hose goes. I took an old DP sensor I had took It apart, drilled It out brazed in a hose fitting sealed up the holes on the sides re installed Orings and it worked.
All functions work fast enough, Your not going to get the speed of a new machine but its workable.
Send me your email and ill send pics of what I followed. I don't know how to post pics.
Kevin
Kevin
Could you please send me the directions and pictures you followed. I’m having the same problem right now. My emailI did the same conversion directions suck and no help. So I printed out all the pictures I could find showing hose routing and pump adapter. Ok got that, then could not find where hose went on valve block. I compared pictures of all the different kits for sale and found one part I didn't have and couldn't buy separately. It is an adaptor to replace DP sensor which is where hose goes. I took an old DP sensor I had took It apart, drilled It out brazed in a hose fitting sealed up the holes on the sides re installed Orings and it worked.
Kevin
Hey daddieboy if you still have the installation instructions for the manual kit could you please email them to me at markolson99cummins@gmail.com. I am dealing with the same problems right now and would appreciate it!Hey Weewards if you are ssking for the installation manual it supposed to come with, yes i do have. Here is my address cadproandassociates@gmail.com
Agree with your opinions.
Regarding to Technical Manual, I never have used the J.Deere manual so I have no idea!! but I have a feeling that HITACHI's documentation is easy to understand also. I attached file for your reference.
https://www.mediafire.com/file/o8dxek1yvr4h5tm/EX120-3_T135E-00_Technical_Manual.pdf/file
I tried sending the tech manual but your email is kick backI have a customer with the Hitachi 120-3 the hydraulic system condition is excessive loading the motor on all functions it will barely move around the owner had it in a pit when problem started, he was able to get it up on the outside of pit. I'm going today to do a basic check on fuses and visual inspection of wiring harness. Does anyone have a service manual PDF file to share also if I find the electronics bad I will suggest the pump conversion. I would like the installation directions if anyone have them... I'm looking at a and for a good place to start diagnostics my e mail is lexc269@yahoo.cim thanks in advanced
my email: arshad_apandi@yahoo.comI did the same conversion directions suck and no help. So I printed out all the pictures I could find showing hose routing and pump adapter. Ok got that, then could not find where hose went on valve block. I compared pictures of all the different kits for sale and found one part I didn't have and couldn't buy separately. It is an adaptor to replace DP sensor which is where hose goes. I took an old DP sensor I had took It apart, drilled It out brazed in a hose fitting sealed up the holes on the sides re installed Orings and it worked.
Kevin
