Hitachi Ex120 Problem
dakuch
Chicagoland
TOOL KING
I sent you a PM , do you think you can help me out with my EX40UR? Thanks JIM
pemolitor
Iowa
TOOL KING. I could use both manuals. I have a -2 machine. I will send you a pm with my email
pemolitor
Iowa
Andre-1, tool king's mailbox was full so I didn't get the manuals yet. I could still use the pics. I really appreciate the help. I've spent a lot of money to have this diagnosed with no luck.
Andre-1
Jamaica
pressure reducing valve
Location: open door on cab side next to radiator and oil cooler, remove air cleaner and the valve is directly in front of you. it has 7 solenoids on it and two valves: pilot pressure reducing valve and pilot pressure regulating valve.
pilot pressure reducing valve is the shorter valve on the extreme right. The pilot pressure reducing valve is used to set the point at which the different applied pressures start to move the flow compensator valves. this is important for combined operations. setting should be 512 +/- 15 PSI. pressure may be increased by adding shims.
Andre-1
Jamaica
this is on the main control valve, looking from the front of the valve/ machine it is the second pilot cap from left to right. this is where you test the pressure in the pilot circuit. this pilot pressure is regulated by the pilot pressure regulator it is the taller valve on the pic showing the pilot pressure reducer, the reducer is the shorter valve where the gauge is shown attached. both contain spring and spools and shims to set the pressure. regulated pressure should be 740 + 140 - 0 PSI when you operate arm out function. engine should be at max power, hyd temp around 50 degrees Celcius , autoidle off,work mode in general purpose. Rememebr this is for a 490E Deere. not sure if the same specs for the hitachi 120. Private message me your email so i can send you better pics and some extracts.
tool_king
new jersey
road mechanic owner
pemolitor
download these links .The tech schimatic drawings and workshop are for dash 5 but should help out .
schimatics
http://www.4shared.com/document/04JXvgIx/01_ELE1.html
http://www.4shared.com/document/CYc8OTum/02_ELE2.html
http://www.4shared.com/document/HDhNxApy/03_CON1.html
http://www.4shared.com/document/g57IuxEN/04_CON2.html
http://www.4shared.com/document/zenNzBVO/05_ENG.html
http://www.4shared.com/document/KXB63oeG/06_CAB.html
http://www.4shared.com/document/KBwHw99h/07_RELAY1.html
http://www.4shared.com/document/o_FIKpER/08_RELAY2.html
http://www.4shared.com/document/3zfJYy--/09_AC2.html
http://www.4shared.com/document/naiymPBf/10_AC1.html
Parts
http://www.4shared.com/document/fBKNvIVx/CATALOG_EX120-2_PARTS_CATALOG.html
Tech manual
http://www.4shared.com/document/IluTD0G5/COMPONNT_OPERATION__CONTENTS_1.html
http://www.4shared.com/document/PnISQRWS/GENERAL_CONTENTS_155T-1-1__3.html
http://www.4shared.com/document/RiHwZklF/PROFORMANCE_TEST_CONTENTS_155T.html
http://www.4shared.com/document/5WkPRWp9/SYSTEM__CONTENTS_155T-2-1__2.html
http://www.4shared.com/document/Ku0DI-8A/TROUBLESHOOTING_CONTENTS_155T-.html
http://www.4shared.com/document/xdGNqzFg/INDEX_3.html
workshop manual
http://www.4shared.com/document/ZJ-tvBQN/ENGINE_AND_ACCESSORIES_W05_2.html
http://www.4shared.com/document/wwKxyuB4/FRONT_ATTACHMENT_CONTENTS_155W.html
http://www.4shared.com/document/soJ-uhvN/general__155W-1-1__2.html
http://www.4shared.com/document/HbvEfdTJ/undercarriage_155W-3-1__2.html
http://www.4shared.com/document/jq4ioR3L/upper_structure_155W-2-1__2.html
http://www.4shared.com/document/EZUOQK_8/INDEX_4.html
Hopefully these help you out.Let me know when you download them.to make sure you got them all.
thanks
ED
tool_king
new jersey
road mechanic owner
dakuch
I do not have the manual for your machine.But their is website that sell manuals for all kinds of machines.They are retty good on prices .I will send the web address to you.
thanks
Ed
Andre-1
Jamaica
Pemolitor I checked it out, it appears the ex120- 2 and 490e are built the same. so the same specs should apply. I have some extracts from the manual I can send you via email
Andre-1
Jamaica
pemolitor
schimatics
Parts
Tech manual
workshop manual
thanks
ED
Tool king I think pemolitor has the ex120-2
tool_king
new jersey
road mechanic owner
Andre-1
I figure any information is better than none when you are in bind.
Can you email those extracts that you have for the 120-2 and 490E .That would be awsome to have the info.My email is tool_king@hotmail.com .
Please feel free to download the links I posted for yourself.
thanks
ED
pemolitor
Iowa
Tool king, Andre-1, thank you for all the info. Hopefully this helps me fix what was told to me to be unfixable. Andre-1 pm sent.
digfaster
indiana
power plant operator / farmer
My 120-3 is having a similar problem, travel and boom functions are extremely slow. Dipper and swing seem to be ok. Anyone have any ideas?
pemolitor
Iowa
pemolitor
What is the problem that they can not be fixd?
I shouldn't say can't be fixed..... they just want me to throw $10,000 parts at it and hope it solves the problem. That just under half the what I paid for it. All the can tell me is I have an internal test without doing and pressure test.
jaytech
jackson ms
nolap the manuals toolking posted on page 13 of this thread are pretty good.
the parts one is for the ex 120-2 the others are for the ex 120-5 which is very close.
thanks toolking
