Hi there,
We have a giant v452t wheel loader. It has basically lost steering and hyd boom up / tilt functions etc - it tries and can move those cylinders slightly but has no power. Steering is difficult and slow, It won’t lift the boom even at full throttle - can use tilt slightly, can use 3rd and 4th function but they are small cylinders and are definitely slower / no power. It has a gear pump that directly feeds the steering orbital valve and then from what I can gather is sends excess oil to the control valve for the joystick as 2nd priority (boom up / tilt / 3rd & 4th function etc). My thinking is the gear pump is poked as I don’t have steering either or is there a possibility the orbital valve is faulty? I removed the tank return line from the orbital valve and oil did come out when I started the engine briefly but I believe it should do that anyway? It would be difficult to plumb in a pressure or flow gauge on the machine because it has metric fittings (not very common here at all) and it’s also very tight and hard to access anything.
Is there another way I can test or try to diagnose what is at fault? The pump gets warm quickly when I boom up or down for say 30 seconds hence my thinking the pump is leaking / worn internally. I’ve attached the schematic for reference.
