It was a totally different experience than when I dealt with the old foreman who worked there over 30 years. He was forced out along with several other long term foremen and senior employee's. 1 hour minimum, OK. Deposit up front? You think I'm not going to pay when you have my parts? It was a combination of things that turned me off. I think the new management is part of it but there are other shops I can take my business to.
When I had some work done in the past the foreman would ask me to come in to see what the problem was and show me what had to be done. Then there were no surprises when the bill came. When the bolt hole stripped on my stick cylinder, they were going to make a new rod and weld the old eye on. I suggested maybe they could drill and tap the rod for a larger bolt and drill the piston bigger. He said that would work and would save me a couple hundred bucks. When I took my leaking rotary swing cylinder in to be repaired he called me once it was apart to show me the problem. The shaft had worn. I was thinking a new shaft was going to be ridiculously expensive if it was even available but he said it can repaired by metalizing which would be about $300. I was relieved but that's what I call good customer service. Not being upfront about a 1 hour minimum and wanting a deposit on top of it is not usual and I don't consider very good customer service.
