Electronic governors are not necessarily electronic engines either. On a Stanadyne pump like that they just replace the top cover with one that contains a governor actuator, which is just a device that manipulates the shutdown linkage directly. Then you set the mechanical governor higher, up and out of the way so to speak, and the electronic governor pulls it back down to 1800 on the button. Electronic is nice but mechanical is nice in its own way.
You are right. I meant full electronic engines. But they come with their own problems. This one does have a 12v solenoid on the injection pump. It has one switch. Flip up, it cranks and then runs by itself with a Murphy shutdown system.
