Hayes trucks in the logging industry
Discussion in 'Forestry Equipment' started by Hayesno1, Oct 3, 2010.
  1. Yellowstar
    Yellowstar Member
    Jan 11, 2019
    5
    Abbotsford
    Wow. Thank you for the info!
    Part of me says that she would be a lot more user friendly with a 3406 b and some more modern suspension with higher gearing.
    I'm a little concerned about rust between the layers of the double frame. Got any suggestions for this?
    Also, can a rad guard still be found? To me it doesn't look right without the guard and a big H on the front!
    Thanks again!
  2. HDX
    HDX Senior Member
    Apr 22, 2010
    1,985
    East Of Sarita
    Yellowstar, That is great. Yes you are right about the engine and rear suspension. Funny enough that you should think that way. It is a very common upgrade today to make these old blister come alive again. As for the rear frame rails, We all have done this. My 1972 HD had this problem. We did the tear down and split the rails. I was lucky enough to find a set of housings that were in mint condition so Vic Rowlinson and I cut all the rear bolts and drove them out Then lifted the frame rails out of the chairs .Undid the cross members and all that was left sticking out was the two rails from the back of the cab to the tail frame. We then split the frame rails and removed all the rust and such. Had new frame inserts bent up and main cross members . We then installed them and started drilling. Pulled all the rear ends apart and installed them in the newer diff housings and all new seals ,Brakes and all else we figured that could be a problem. Vic repainted the back end and we were back in business. I should have gone with the upgrade Nuway or Pete -airtrac air ride suspension, This would have been the way to go. But being a purist I kept the rubber block suspension, Kind of like driving a 2X4 with steel wheels You kill two birds with one stone so to speak, Because you will never touch the back end again . Then you get into the engine department. How much power would you need/want. For the most part , The 3406B is more than enough for whatever you would want. By going this route ,you would not need to install the air to air assy, and that is a pain in the a##. You can still keep your shutters and for all intents and purpose nobody can tell that you have changed anything because it still looks like a NEEDLE NOSE HD Hayes and it rides like a mattress. There are steering changes you can do to replace the old Vickers system as well if you so decide. I went with the original 8V71 N and installed dual 9 inch Donaldson mufflers and stacks. This was a little problematic as for visibility because it does tend to give you a blind spot on the drivers side, Just something to think about if you lay out your plan to go this route. There are brushguards around, and not really hard to come up with. I saw in the pictures that the battery box cover was laying on the ground, Be sure to grab that ,if for no other reason that having a template to make a new one if needed. Also ,look around and ask him if he has the muffler guard around in the shop maybe, with the engine side panels. Sometimes these were removed because the new muffler was a 10 inch instead of an original 9 incher and the brackets would not fit anymore. All this is not a biggie because they are around and not hard to make. Trust me here The new wrap around ones with all the holes in them like the Kenworth ones don't work they look like hell and just don't look right. Stay with the original style with a grab handle,they were and are the best.. Well what else are you concerned about??? You can always PM me if it gets intense LOL
    DMiller and diamondtguy like this.
  3. KPhelps
    KPhelps Member
    Jan 29, 2015
    19
    Dentist
    Nanaimo
    Bit of a tragedy unfolding at the Nanaimo Lakes dry sort. A mix of HDXs and P-16s that came here under their own steam a few months back.
    Greatwestcam, 72hayes and DMiller like this.
  4. HDX
    HDX Senior Member
    Apr 22, 2010
    1,985
    East Of Sarita
    Will investigate further and get back to you about these... And their future
    DMiller and dirty4fun like this.
  5. DMiller
    DMiller Senior Member
    Feb 22, 2010
    4,313
    Retired
    Sad to see functional machines torn apart for pieces.
  6. KPhelps
    KPhelps Member
    Jan 29, 2015
    19
    Dentist
    Nanaimo
    How they looked last September.
  7. Hallback
    Hallback Senior Member
    Jun 1, 2011
    881
    Contract logger and cutter
    Centralia Wa.
    I really want one to build a line horse out of or already rigged as a horse.
    DMiller likes this.
  8. HDX
    HDX Senior Member
    Apr 22, 2010
    1,985
    East Of Sarita
    They must be still using the two P16's on the far left. Both these trucks were Hayes Forest trucks .units T519 and T521. Both of those trucks have BD121 Rear ends and 18 speed trans in them. They were bought new by Pat Carson in 1986 along with a third truck T517. That truck was kind of for sale last year over on the sunshine coast along with a lowbed trailer. These three trucks were part of the acquisition of the Pat Carson Fleet when Hayes Forest bought out PCB
  9. ben46a
    ben46a Senior Member
    Mar 11, 2007
    772
    Waverley NS/Fort Mac AB
  10. Hank R
    Hank R Senior Member
    May 29, 2014
    1,058
    Retired Truck driver and School bus driver
    Princeton B.C. Canada
    My thinking a Hayes by the front bumper etc. ???
    ben46a and DMiller like this.
  11. HDX
    HDX Senior Member
    Apr 22, 2010
    1,985
    East Of Sarita
    It is a 1973 HDX Hayes. Was a BCFP truck that went to their Nekite Division new. Had a hydraulic ram mounted under the truck bunk for hooking up to the lowbed trailer
  12. Born2clearcut
    Born2clearcut Senior Member
    Jan 11, 2011
    417
    Sunshine Coast B C
    I think the blue and white Hayes ended up in Narrows Inlet BCFP division where it was painted from orange to the blue and white. The whole fleet got painted one winter after Interfor took over from Fletcher Challenge who took over BCFP
    ben46a likes this.
  13. HDX
    HDX Senior Member
    Apr 22, 2010
    1,985
    East Of Sarita
    She must have been rebuilt at the same time then , the Pacific cab, Fenders and hood and brush guard must have been added at the same time. What do you think???
  14. Born2clearcut
    Jan 11, 2011
    417
    Sunshine Coast B C
    hayes lowbed (2).jpg hayes lowbed (3).jpg This truck #6-247 got a in house ground up rebuild in Narrows at the time everything got painted . This would been around the mid 90's . Last time I saw it (above pics) was in Powell River 2011. I think they may have rebuild one other one at that time. If those trucks are Horsemans their is a good chance it's a Narrows truck. I think Gary bought one or two when Narrows close down and joined Clowhom falls
  15. HDX
    HDX Senior Member
    Apr 22, 2010
    1,985
    East Of Sarita
    Steve, I wonder if in fact then if this is not 6-248, the sister truck . They both had the hydraulic ram under the truck bunk. the one picture'd in the Nanaimo lakes sort yard on blocks still has the Hydraulic tank mounted on the drivers side of the water tank in the ladder. the boxed in top of the water tank on each side of the saddle was done to one of them. not sure which one it was without going back through Al's pictures from up there. The picture you posted above was the one I saw with her for sale somewhere on the sunshine coast some years ago. time will tell if I get over that way and get to see her... The search continues... You might have posted pictures of this one some years ago . Seems there was a picture of the dash layout in her also.
    dirty4fun likes this.
  16. Born2clearcut
    Jan 11, 2011
    417
    Sunshine Coast B C
    Yes I did post this truck a few years back page 39 in this thread. Greatwestcam posted a couple pictures of the dash on same page 39.
    DMiller likes this.
