I had to custom fit 4 separate fenders, due to the oddball spacing since I am using torsion axles, the standard tandem fenders were much too long. I mounted the torsions as close together as I could, due to their load sharing characteristics. I did one side, and before doing the other it occured to me to load up the U 25 for the first time and see how much deflection I got, to make sure i had left adequate clearance. Good thing I did, one mount bracket had to be shaved down with a skinny wheel, and the second set was built with that mod standard.
As long as I had it on the trailer, I figured I might as well take it for a spin on the country gravel road I live on. No brake wiring yet, and not the binders I'll be using but it towed fine and handled great. Back in the shop, I figured up my empty unsprung weight, using standard steel weight tables plus adding the misc. things like the hitch, jack, and fenders. 989 lbs., with an all up weight of 1309. More then a ton less then my dump bed trailer, living on a mountain side 1200' above the valley floor, I'm a weight weenie and have been for decades. No way do I want to pull (and descend with) more then a ton extra everytime I haul the mini. the intent of this trailer was to be a bare bones U25 mover, the dump bed will be my gravel hauler, trash hauler, and the trailer I'll lend out to friends for moving or whatever. Out of pocket expense was $2200.00, less by a fair amount then I could have store bought something that wasn't what I wanted. I will keep this inside, so wanted it just long enough and no more, but rather then waste material (main frame is 5" channel, with 3' channel and 2' angle iron for the walkway) I used up the 20' lengths and made it 13'. I had planned on 12' at first.
I drive up it blade first, facing forward, and use the blade to control the tip over from the ramp angle to the bed's angle, nice and smooth. Coming down, I spin the house around and use the boom to make the opposite transition smooth an unexciting as possible. Next will be wiring the lights, brakes, and breakaway system, safety chains, and I'm done. One unexpected feature of using the torsion axles, is when I jack it up to clear the ball, the forward axles clear the ground, so with a wheel on the jack end I can easily roll and position, as long as I'm on a concrete floor that is, a huge advantage over a trailer with all 4 wheels on the ground. I think I nailed my CG pretty good, I'll make a trip over some scales once in town and get an idea but it feels and looks about right.
