Harvest 2024
colson04
Delton, Michigan
Fall Harvest is gearing up in the US. Some places are running wide open already, while others are just getting equipment out. We chopped our corn silage the first week of September, and our soy beans are almost ready to roll. Corn always gets run after beans around here, unless making high moisture corn, then it may have to be shelled a bit earlier when the moisture is right.
Here are some pics from our silage harvest. We chopped around 200 acres over 6 days. We don't get started until after 10am, and shut down around 6pm to prep equipment. Dairy business happens first, then we move on to everything else that needs to happen.
I spent my time pushing up the pile, packing the pile, driving truck, or fixing trucks. I also spent every evening prepping the push tractors, our 7380 harvester, and the trucks for the next day so we would be ready to roll when we got done with chores. It was a very busy 6 days, as every day started before dawn and finished after dusk, but the weather cooperated and stayed productive every day even with 3 trucks breaking down. One truck lost a steering box and was taken to a heavy truck repair shop. Another truck had to have the starter and positive battery cable replaced. Both of these trucks were down for a day each, but didn't slow us up too much. Our third truck is still at a repair shop as it developed a bad miss when warm and loaded. They sorted out an electrical issue, and are currently waiting to hear results from injector testing.
92U 3406
Western Canuckistan
Wrench Bender
We're a couple weeks in up here now. Wish the weather would start co-operating. We have a day or 2 of good weather, then it rains. Forecast looks good for the next week so hopefully everything dries up today and tomorrow so they can get back in the fields.
colson04
Delton, Michigan
Got into the soybeans today. Ran a field of 1.8s that were planted April 21st. Light soil, good rain, 63 bushel/acre @ 10.5% moisture. Not bad given the deer leveled the back 2-3 acres. Low spots in the field were touching upper 70s for yield. I was on grain cart detail tonight. We'll run another 100 acres tomorrow.20240917_164731.jpg20240917_171354.jpg
colson04
Delton, Michigan
Another beautiful day to run soybeans
4040 auger mule earning her yearly keep.
We did use this tractor to drill some Alfalfa back in August when we had a couple cools days, but otherwise she doesn't so much field work anymore. Used to be our go to utility tractor, but its been supplanted by a newer, cab tractor with AC.
stinky64
java center ny
big truck wrench/fixer of things
Drove past a tater pickin' operation yesterday, three big green tractors followed by three big tater pickers. It's been pretty dry around here lately so them big tater conveyors blowing all that dry dirt from tater hills up into the air looked the riders of the apocalypse coming through. Only beans being harvested around here so far are green beans and a whole bunch of punkins' by the side of the road.
colson04
Delton, Michigan
Very busy week. Harvested around 200 acres of soybeans, harvested 50 acres of earlage, and helped truck earlage for two neighboring farms. One of the farmers has the adapter to put a snapper head on his Claas harvestor, us and another farm provided trucks.
The neighbors did a really nice job cleaning up this Mack. Both of our Mack's and this one came from the same custom harvesting operation when they upgraded their fleet. Our trucks are not as sharp looking as this one. Their effort is noticed by everyone when people ask "Who has that shiny truck?"
Always seems like we have to split the field when its my turn to get loaded.
We started the first farm on Wednesday and finished the third farm this morning. That is one fast operation. Normal corn silage for us is chopped around 3mph. We were running 6-9mph chopping this earlage. We did around 50 acres at our farm in about 4½ hours. Part of that was moving between fields as we chopped off some smaller parcels. The neighbors put their earlage in bunk silos, we filled a 10ft diameter x 250ft long Ag Bag. This is our first year trying earlage in a dairy TMR.
colson04
Delton, Michigan
Work hasn't slowed down any this week. Spent Monday and Tuesday going through equipment, then set up a bagger and grinder on Wednesday morning and started shelling high moisture corn for cattle feed. Corn is coming out of the field around 28% moisture, a little wetter than the hammer mill likes, but it's handling it well. Wetter HMC ferments better and makes a more digestible feed stuff. Our schedule is mostly dictated by the availability of the rental mill and bagger though. If the corn is close, run it. Been some late nights, but we should finish this evening.
colson04
Delton, Michigan
Hammer mill lost a universal about 4 hours into the job on Wednesday. Made a hell of a racket when it let loose at 1000rpm. Shut us down right after all the shops closed. 20240925_174636.jpg20240925_174640.jpg
colson04
Delton, Michigan
At least the tractor end U-joint broke, could have been bad if the other end let loose.
It still flopped pretty good as there is a lot of inertia in the hammer mill when it is spun up to 1000rpm. The shaft spun around and hit something which snapped the shear bolt on the flywheel side. It took another minute or so for the mill to stop spinning. I happened to be in the tractor when it went and was able to kill the hydraulic augers pretty quick so we didn't fill the mill with whole corn too badly.
colson04
Delton, Michigan
Manure injection guys set up on Monday/Tuesday and started pumping our lagoon on Wednesday. They should finish today, or Monday. View attachment 321899View attachment 321900
Guys shut down at 6pm and still had about 4ft left in the lagoon. They didn't have a very good day either. They broke their injection toolbar mid-day, snapped the frame. They left and brought back their backup tractor and toolbar only to blow a hydraulic line on the tractor before they could get back to pumping. This tool bar was 3pt mount, and their other tractor didn't have a 3pt hitch. Their motor hand said its been like this all summer. Everything they touch breaks. Get things repaired or replaced and something else lets loose. They spent the rest of their day getting the broken frame toolbar functional to top dress instead of inject. We'll have to disc it in once they're done to incorporate it.
