leadfarmer
Oh boy, looks like that bushing is in the transmission case itself, not the removable top cover. I will have to remove the linkage arm and see what I can do.
So linkage was fine, trans is low on fluid, and gear case is quite high on fluid. Whats the cause and solution for this conundrum? I added fluid to the trans and it moves again.
Is there another way the trans fluid can migrate into the bevel gear case other than the seal around the shaft between the two?
