hancock pull paddle scraper
gwhammy
missouri
How are these to use and maintenance wise? We could use a scraper every now and then but not enough to sink much money in one. More wanting than justifying one. I see them with pto and hydraulic chain drives.
Tones
Ubique
I don't know how you would have one PTO driven without some serious engineering to stop the drive shaft hitting the gooseneck. They were all hydraulic or electric driven elevators including the Michigan which had the drive motor mounted down low with a drive shaft up to the sprockets. Having a hydraulic pump driven off the PTO could work through.
gwhammy
missouri
I thought I had seen pictures of them with PTO's but could be mistaken. A guy local has a couple of them I just need to take some beer and BS him about them.
56wrench
alberta
I’m not sure why you would want one of them unless you are a collector. An open-bowl conventional of the appropriate size matched to the tractor would be a better choice with a lot less maintenance. All those moving parts would give me nightmares. I ran a JD paddle scraper once and it was ok for finishing work but I wasn’t the guy fixing it
bigrus
Southern Queensland Australia
Universal soldier (operator)
Looks more Wabco 111A or International E200 era.
Electric motor removed & old style John Deere drive shaft/gearbox
Michigans had a Hough loader diff & planetaries on the lower section of the frame
Tones
Ubique
All the Inters I've worked had Johnson bowls, same as Cat
