Hollywood627G
You normally load in second, but if you wait for the machine to shift down to 2nd, lock it in gear, then hook up is too slow. Use the cushion in the pushblock and stab your brakes to hook up smoothly and quickly and in a higher gear than 2nd, normally 3-4. You dont push in 3-4, unless in mud as previously stated, but it is quicker to hook up in those gears. If done correctly you scare the sh*t out of the lead hand because it looks like youre going to slam him, but really youre buttery smooth.
I didnt mean to just bomb the material in the fill, but 2-3 gear is to slow 95% of the time. Around here the super's will time you, and if you arent fully loaded in a certain time, youre off the machine. No skimming to clean up, you gotta learn to keep it clean while mucking. A 27 cant gouge 3 ft. holes, but it can take 12" out smoothly.
