I believe the owners name is Larry...It apparently is truck # 4 if it is indeed the old Kozy Kleen truck...Pictures would be great....
My steering dilemma....Hydratech says to ditch my atf fluid in the pump and switch to synthetic.They also said to put some miles on it and work the air out..I have not heard back from Can Craft...
Today my friend brought over a Chevy 1 ton steering pump and parts from a truck that used a hydraboost..The pump has a better can on it with 2 return lines and a external reservoir fitting and tank...I got the relief valve as well.....I may rip my system apart and install the 1 ton stuff along with the different relief valve...Its a crap shoot but worth the risk....Left over parts will just get used on my Diamond T.
I started cutting out the rear wheel tubs today...They are in bad shape (rust) and the other week I realized I don't even need them.They will be deleted.This will make putting a rubber mat in the box very easy (sort of)...
