Greasing Machinery
Discussion in 'General Industry Questions' started by d4dozer, Jan 4, 2015.
  1. buckfever
    buckfever Senior Member
    Aug 13, 2010
    813
    southwest pa
    We have 4-5 lock-and-lube fittings. One is on our air greaser and the rest we have regular Lincoln pump guns. We love them and our local hose shop can make flex hose as long as you want for your gun. Get a hose about 2 feet long and clip it to the fitting and stand back and pump. The ones we got also came with one rebuild kit. So if it wears out ( which after 4 months of daily use it has not) you can just rebuild it and be back to new.
  2. Landclearer
    Landclearer Senior Member
    Oct 3, 2012
    1,139
    Southeast
    Thats a good point. We might have to put up with changing tips on a regular basis.
  3. Landclearer
    Oct 3, 2012
    1,139
    Southeast
    So you do not have any trouble getting the tip on any fittings?
  4. Shimmy1
    Shimmy1 Senior Member
    Aug 14, 2014
    2,778
    North Dakota
    Is this what everyone is talking about? http://locknlube.com
    This one is different I think than some others I've seen. This one might work.
  5. buckfever
    Aug 13, 2010
    813
    southwest pa
    I can only think of a couple that it won't work on and they are the ones sandwhiched between a bunch of hydrolic hoses.
    Shimmy1 those are the same ones we have.
  6. willie59
    willie59 Super Moderator
    Dec 21, 2008
    12,474
    Service Manager
    Knoxville TN
    Yes, that's it. They're a little spendy, but worth every penny. I use them exclusively on my service truck grease pump and the shop grease barrel, I WILL NOT EVER go back to using conventional grease couplers, I'd pour gasoline on my head, set it on fire, and have a helper put the fire out with a sledge hammer before I did that. :yup
  7. Landclearer
    Oct 3, 2012
    1,139
    Southeast
    Just ordered one.
  8. Shimmy1
    Aug 14, 2014
    2,778
    North Dakota
    I'm going to give one a try, too.
  9. willie59
    Dec 21, 2008
    12,474
    Service Manager
    Knoxville TN
    They're excellent for grease zerks that are fitted into a recessed hole, no more fighting to get the coupler loose for lack of side movement required to release the coupler because no wiggle room allowed by the hole.
    The only problem you'll find with the lock n lube is when you run across a joint that won't take grease, that will lock that thing down so tight that you can't get the sleeve to pull back and release the coupler. The more grease pressure you have on the line, the tighter it grips. A grease locked fitting will lock it down until you relieve the pressure. My remedy was to install a high pressure needle valve on the grease gun hose. If I run across a locked down fitting, I simply open the needle valve and relieve the pressure. The 1/8" brass plug on the bottom of the valve has a 1/8" hole drilled in it, makes it easy to wipe away the grease I just released.
  10. buckfever
    Aug 13, 2010
    813
    southwest pa
    Willie that is a great idea. Had one lock up tight once and had to unthread the hose from the gun, what a mess.
  11. clintm
    clintm Senior Member
    Jul 8, 2013
    974
    charlotte nc
    willie engineering at it's finest! they tell you in the package to take your old end and screw a grease fitting in it and you have a handy adapter to fit in those tight places
  12. willie59
    Dec 21, 2008
    12,474
    Service Manager
    Knoxville TN
    Had the same happen to me buckfever, and yes, mess, not to mention the PITA part, hence the remedy. And I used steel hydraulic pipe fittings, not brass, because of the pressure involved, wouldn't want it to burst from the pressure. The only thing that's brass is the 1/8" pipe plug with the hole on the end.
  13. farmerlund
    farmerlund Senior Member
    Nov 23, 2014
    619
    Farmer/ excavator
    North Dakota
    Hey pondo,
    I have added extension hoses to many zerks that are hard to get at. Most equipment dealers or parts stores have or can make a little hose for it. I like to make a little bracket out if angle iron or flat iron to hold the new end.
    Really saves time for hard to get at fittings.
  14. pondo
    pondo Well-Known Member
    Mar 24, 2013
    173
    canada
    Cool thxs guys. I will look at those locking grease gun fitting.
  15. alaskaforby4
    alaskaforby4 Senior Member
    Aug 3, 2010
    418
    Owner Operator
    Alaska
    Always a greasy nightmare servicing these machines. I bought a 18v Lincoln grease gun and it changed my life! I am finally able to hold pressure on the zerk and fitting and just pull the trigger!
    I then purchased a Dewalt 20v greaser and it is even more amazing yet! I can pump around 5 tubes depending on the temperature with 1 battery. It was cheaper than the lincoln and in my opinion its a better gun. even has a little light on it for "night greasing" :)
    Good luck and keep fighting the good fight!
