JimInOz
Hi Guys,
I'm replacing both seals on the Bevel gear in my little Mitsubishi dozer...oil is leaking from bevel housing into steering cases.
The shop manual says I need to "fill up the lip space with grease" before inserting next to bearing.
Any ideas why this would be required,& the type of grease I need to use.?
My bearing supplier was confused,as we figure the bevel oil will be doing the lubricating in there anyway...?
Maybe someone has seen this before.
Thanks,
Jim
Thanks,
Jim
