Grease - All the Questions You Wanted to Ask - But Didn't
Discussion in 'General Industry Questions' started by Chris Sulentic, Jun 12, 2019.
  1. Chris Sulentic
    Chris Sulentic New Member
    Jun 12, 2019
    1
    Northeast Georgia
    I have the following questions about GREASE...
    1. Do I need to move my case of grease inside to avoid freezing temps in the winter?
    2. I try not to overgrease, but does it cause any serious problems?
    3. What to do if your grease gun gets caught on a zerk? I broke a zerk fitting some time back trying to get the grease gun off the zerk, and it royally p'd me off. Made me a little gun shy.
    4. I assume you can mix synthetic with non-synthetic grease 'cause how are you going to do it otherwise if you change from one to the other? Do you never change? I know the simple answer is to just follow the manufacture's directions, but would like a deeper answer if there's one out there please.
    Thanks in advance,
    Chris
  2. JD955SC
    JD955SC Senior Member
    Mar 14, 2011
    350
    The South
    2) if an open bearing such as a pin where the excess grease just flows out no, it just makes a mess. If something like a tie rod end where there is a boot or other method of sealing then you don’t want to overgrease. Another area where it’s possible to overgrease is the swing on an excavator
    3) just get it off best you can and keep a spare assortment of grease fittings and a couple of spare couplers handy. What’s causing this is pressure lock from the component not taking grease- you have a clog issue. Often it’s not the zerk itself
    td25c, DMiller and Chris Sulentic like this.
  3. fast_st
    fast_st Senior Member
    Dec 1, 2010
    1,171
    IT systems admin
    Mass
    1) Not a concern, storage temperature won't hurt grease, think of every service truck out there. Warm grease is certainly easier to pump but it will be bearing temperature in a hurry.
    3) sometimes you have to cock the lube adapter a little to get the pressure off but you might want to see if that fitting is mushroomed from impact and needs to be changed. I change any pesky leaking fittings.
  4. 007
    007 Well-Known Member
    Dec 28, 2016
    207
    3) When your coupler becomes locked you can unscrew the cup on the end which allows the jaws to relax.
    The four Jaw type get stuck more often than the three jaw type.
    The four jaw type hang on better when greasing but the three jaw go on and off easier.
    Have tried many couplers some costing over 100 dollars but i find the best one so far is a relatively cheap one you can get on ebay called a g-coupler.
    Highly recommend.
    4) There are hundreds of web pages covering comparability between grease types so you will have to do some research as is a complex subject.
  5. Tinkerer
    Tinkerer Senior Member
    May 21, 2009
    3,771
    On A Riverbank in IL. USA
    Welcome to HEF, Chris !
    td25c, CM1995 and mg2361 like this.
  6. Vetech63
    Vetech63 Senior Member
    Aug 10, 2016
    1,721
    Oklahoma
    Cold weather doesn't affect grease. What it effects is your arm muscles when it's being pumped with a hand gun at 10 degrees.
  7. DMiller
    DMiller Senior Member
    Feb 22, 2010
    5,723
    Retired
    As far as Synth or Conv grease and using a tube feed gun, keep one for each so do not cross contaminate, I currently have four, one for Organic(Farm Implement) grease, one for Synthetic lube I use on two machines, one for inexpensive conventional lube for a tractor that just gets greased each use and a final one for Hi Temp Hi Shear lube for heavy pivot points(think Loader pins, cylinder eye pins etc.) Used to have a fifth unit for Marine based Greases, got rid of my boats.
    RZucker likes this.
  8. DIYDAVE
    DIYDAVE Senior Member
    Feb 18, 2007
    1,476
    MD
    In my experience, its not temp, that makes grease separate, its age. Don't buy no more than you can use in a season or 2, and never buy it at auction, that stuff always seems to be bad, LOL!;)
    RZucker, Pixie and DMiller like this.
  9. grandpa
    grandpa Senior Member
    Oct 16, 2009
    1,725
    northern minnesota
    Why does grease always jump on me!!
    aighead, td25c, walkerv and 3 others like this.
  10. DIYDAVE
    Feb 18, 2007
    1,476
    MD
    I think its a sub set of murphy's law...;)
    td25c, grandpa, walkerv and 2 others like this.
  11. DMiller
    Feb 22, 2010
    5,723
    Retired
    Kind of like that single drop of anti-seize that spreads like a California wild fire.
  12. CM1995
    CM1995 Super Moderator
    8,848
    Welcome to the Forums Chris!
    1 - You live in north GA, no need to worry about your grease getting too cold.
    2- Excessive over greasing makes a mess on a standard pin and bushing. Although I like to see some squirt out.
    3 - I stand beside Lock-N-Lube grease gun tips. https://locknlube.com/
    4 - No you don't need to mix grease IMO.
    I have had the best luck with Phillips 66 Megaplex XD5 No. 2 grease. It's a 5% moly grease that's good with P&B's under load. We get it from our fuel supplier.
    Also this is money well spent IMO, we have 3. 18V Milwaukee grease gun, tried the Dewalt and it sucked wouldn't
    keep a prime.
    Well worth the $180 for the tool only.
    td25c and DMiller like this.
  13. RZucker
    RZucker Senior Member
    Jul 7, 2013
    3,138
    Mechanic/welder
    Wherever I end up
    On your nose, in your eyebrows, and a little war paint on your cheek?
    Spud_Monkey and DMiller like this.
  14. Spud_Monkey
    Spud_Monkey Senior Member
    Sep 15, 2018
    309
    Retired Veteran Mechanic/Welder
    Wherever I may roam...
    In places you can't reach too or wonder, how in the $#&* that get there.
    RZucker, td25c, grandpa and 2 others like this.
  15. grandpa
    Oct 16, 2009
    1,725
    northern minnesota
    Guess it not just me!!!!
  16. td25c
    td25c Senior Member
    Feb 15, 2009
    5,251
    indiana
    We will throw a few tubes of grease on top of the hydraulic tank on the excavator so it warms up & flows better in cool weather .
    Lunch is on the exhaust manifold . LOL ! :D
    aighead and DMiller like this.
  17. DMiller
    Feb 22, 2010
    5,723
    Retired
    Last time I tried that forgot it was there until it exploded, critters liked the old tractor after that A LOT.
    Spud_Monkey likes this.
