Tinkerer
Yes Swetz, I can carry good sized logs for miles if I wanted to. On the farm nothing is too long. I can go thru gates or between trees easily by going through at an angle and manipulating the hoe at the same time. Most of the time I just extend the boom up for gates. Depends on how heavy the tree is.Tinkerer,
Are you saying that you grab a large log and carry it a good distance (like acres) with the thumb on the backhoe. I would assume if you are, then rotate the boom to the side as cheroniekon talked about. I never thought about this for distance. It seems the weight over one side would make the tractor unstable?
I do sometimes carry logs with the boom swung to the side. Boom all the way up and dipper nearly all the way in. Weight of the load is the limiting factor when carrying like that. I usually extend the stabilizer under the log / tree to help carry part of the weight.
